Question about Hasselblad Extension Tube 16e
I am using the 500c/m with the 80mm 2.8 T* and it works very well. But when I add the extension 16E and push the shutter release, instead of the well known Hasselblad shutter sound, it makes just a faint 'click' sound. After releasing I keep seeing the normal image on the focusing screen. Film advance and shutter cocking seems to work fine afterwards. I don't have a developed film yet, so I have no idea what the taken photograph looks like. What am I doing wrong?
4 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Hasselblad 500cm body frozen/jammed
Check the release button lock tab, it may be engaged, holding the release button in
Posted on Aug 19, 2009
SOURCE: Underwater housing parts
Hi this is an old housing you have to make the parts yourself, film advance adapter, it is dificult to make one. But toothed diaphram and focusing ring is easy
Posted on Sep 29, 2010
pabloloco
  • 2335 Answers
SOURCE: Hi, i am getting photographs
Sorry to hear about your Hasselblad optics issue.
I am aware of an excellent thread that goes through troubleshooting the very problem you are having.
Instead of reproducing it all, I will point you in the correct direction.
I hope that helps.
Posted on Mar 14, 2011
Nikon N65 with Nikkor 35~80mm AF lens will not focus or shoot
N65s were notorious for bad shutter release buttons. The metal is thinner than a strand of hair and they break. Search Ebay and see if the part is available to replace (note: Nikon stopped selling parts last year).
Feb 17, 2014 | Nikon N65 35mm SLR Camera
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Planar 80mm T*,wrong 1,2,4 speeds
I have been repairing Hasselblads since 1991. I can tell you that removing the shutter for repairs is a time consuming task that requires patience and tolerance. All of the screws are flat blade, nine in particular that are hard to reach without the proper set of drivers.
The shutter has a gear train that needs to be cleaned and lubricated to fix the lower speed problem. It is common since they are rarely used in commercial work
Sep 23, 2009 | Cameras
I have a Hasselblad 500c/m with the lens stuck on the body and I not turn the shutter knob. Help!
Get the back off the camera, make sure you can see inside the camera and locate a chrome screw in the middle below the lens.
Turn it right to align the locater slot of lens and body. Be very careful and do not use to much force. If you turn it enougn you can use the release button an unscrew the lens by turning it anti-clockwise.
Sep 19, 2009 | Photography
I have a Hasselblad 500C/M camera and can't get the lens on.
http://www.butkus.org/chinon/hasselblad.htm
Get the manual. They are picky, it might require the shutter to be wound or something like that.
Jul 01, 2009 | Planar Normal 80mm f/2.8 CFE Lense
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Dropped the camera and now...
Sounds like the chassis under the shutter button has somehow distanced itself from the shutter release button, maybe bent away from the button? Its s stretch but that maybe the problem. The button is designed to have 2 contacts in it, the autofocus switch and the shutter release depending on how much you press it, like most cameras
Nov 09, 2007 | Olympus SP-500 UZ Digital Camera
Orange Warning Light
I recently had a similar problem and found the answer to be the shutter release on the lens itself.
When the using the shutter release, (mirror up feature), on the lens the shutter release, screw in portion, in the lens will actually will pop out to accomidate for the cable release.
There will be a small red circle around the base of the area where the cable release would screw into.
Try pushing that back in. Worked for me.
Good luck,
James
Oct 19, 2007 | Mamiya RZ67 ProII Medium Format Camera
Shutter release button is stuck
You have two choices 1. take it to a repair shop and get a quote[almost the price of a new camera I wager] 2. Try your self[bearing in mind that if you cant fix it you'll have to buy a new camera] Chances are the in dropping it the button has forced it self through an aperture in the casing so that it cannot return. If you have access to fine screw drivers[Jewellers/watchmakers]slack off the screws holding the case together- done take 'em right out just slack 'em-it might pop right back out- if it does tighten up.
May 06, 2007 | Canon PowerShot A75 Digital Camera
Hasselblad Extension Tube 16e Logo
85 people viewed this question
Top Hasselblad Cameras Experts
Steve
Are you a Hasselblad Camera Expert? Answer questions, earn points and help others
