Question about Samsung Galaxy Y Pro B5510 White Unlocked Touchscreen Qwerty Keyboard
Reset gt-i5550 - Samsung Galaxy Y Pro B5510 White Unlocked Touchscreen Qwerty Keyboard
How do i reset internet explorer 11
This may help you.
>> Open Internet Explorer on your PC
>> Press Alt and look the menu bar has been showed up.
>> Go to Tools > Internet Options
>> Go to Advanced Tab
>> There you will find the Reset button.
It can reset your internet explorer.
Thanks a lot.
Sep 22, 2014 | Computers & Internet
Iphone stopped working
I don't have a lot of information to go on, but does this possibly help?
  1. Settings -> General -> VPN (should be not connected, if this is a personal device)
  2. Settings -> General -> Cellular -> Cellular Data (turn off, reset the device)
  3. After the device boot-up
  4. Settings -> General -> Cellular -> Cellular Data (turn on, reset the device)
IF that doesn't help (follow this )
  1. Settings -> General -> Reset -> Reset Network Settings (this will delete all Wi-Fi passwords)
  2. Settings -> General -> Safari -> Clear History -> Clear History
  3. Settings -> General -> Safari -> Clear Cookies and Data -> Clear Cookies and Data
  4. Settings -> General -> Safari -> Advanced -> Website Data -> Remove All Website Data -> Remove Now (** All data saved in Safari will be deleted)
  5. Reset the device
Aug 07, 2014 | Apple iPhone 3G
Vibration mode is not working on vibrate Mode as well as Sound Mode on my Samsung GT I8262
hear try or reset all if well done f we not ur hardware of cp is problem
How to Soft Reset or Reboot or Restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
There are several ways to do soft reset or restart, the easy way to soft reset or reboot or restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL by remove the battery and then put again to the place then turn on the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL. If you do not want to open the battery, you can do easily with pressing Power Button for several seconds and the option menu to turn off or reboot will appear.
#Option 1, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with software menu:
  1. Turn on SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  2. Make sure SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL battery is not empty
  3. Go to menu: Setting > Backup and reset > Factory Data Reset > Reset Device
  4. Choose Erase Everything
  5. SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will do the process to Master Reset to Factory Default, wait for several minutes.
#Option 2, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Hardware key button:
  1. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL charge properly
  2. Turn off SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  3. Press and hold together : Volume Up Button + Home Button & continue with Power Button (together)
  4. If we see the menu at LCD screen, choose Wipe Data/Factory Reset with Volume Button to select and use Power Button to ok or enter.
  5. The SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will doing the process of restoring to factory default.
#Option 3, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Secret Key Code Security:
  2. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL not empty
  3. dial or press number to call: *2767*3855#
  4. That number code will force format SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
How to Restore and Reinstall Clean Android Operating system / firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
Do not worry to do reinstall or restore the clean and default setting Android operating system or firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL because the file source already saved inside the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ROM. If we think the phone really need to be reinstall or restore the default Android operating system or firmware, then we can do it easily by doing hard reset or master format step above, because the operating system will be reinstall by itself.
goodluck sir.
Jul 04, 2014 | Samsung Cell Phones
Why is my linsay tab is stuck on the reboot screan
There might be problem with your firmware version of the device.
Do a hard reset of your device, hopefully it will be solved. Here is the instruction:
Suggested From: Samsung Galaxy S6500 Unlock Code Sim Network Pin
Performing a Factory Reset on Samsung Galaxy S6500:
1. Hold both the volume up key and the power key at a time to start the phone.
2. Command to Factory reset /wipe data>>>delete all user data>>>reboot system now
3. HARD RESET COMPLETE.
How to Hard (Master) Reset?
1. Select "Menu">>> "Settings."
2. Go to "Privacy">>>"Factory Data Reset".
3. "Format USB Storage" CONFIRM TO CLEAR DEVICE..
4. "Reset phone.">>>"Erase Everything" confirm to reset to factory settings.
Jun 22, 2014 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
Email is coming through but won't load up properly
this iphone repair is rated "EASY"
you will need to reset setting on your iphone. follow these instructions. by reseting your phone setting you will not loose any data.
goto >> setting >> General >> reset >> reset all settings
Make sure to use only first option in your reset page. use only " Reset All Settings"
you are good to go.
tech from
iphone repair brampton
Jan 31, 2013 | Apple iPhone 3G
I was given my late father's Navman F20 when he died in November... i have reset all the details but it keeps telling me that my home address is in a village 4 miles away? it does not recognise my...
I definately wouldn't toss it out yet. Most GPS' are pretty solid and last for years. Sometimes they just need an update...or a jumpstart! Here are a couple of things to try:
1) Try the following reset options. From the menu on the device, go to: Preferences --> System --> Reset --> Delete Preferences. Preferences --> System --> Reset --> Delete Favourites . Preferences --> System --> Reset --> Delete Recent Addresses. Preferences --> System --> Reset --> Factory Reset. This option restores ALL settings to factory defaults.
If that doesn't work, then perform this step: Preferences --> System --> Reset --> GPS Reset.
After you complete the steps above, then take it outside to allow it time to 'find itself' (this may take 3-5 minutes), and see if the position becomes accurate again.
Hope this helps! Cheers!
Jun 21, 2011 | Navman GPS
I want to how to give hard reset in k610i but how can i give it can you please tell me step by step
hi
if u want to reset your phone .. then take your phone data reset . process is setting >>>>> master reset >>> reset >>>>
...then your phone will be reset ted
thank you
Dec 22, 2010 | Sony Ericsson K610i Cellular Phone
WRT150N. The power led on is small. can´t connect to wrt150n wuith fixed address (192.168.1.5) in my netword settings. I try hard reset but nothing happing
>>make sure first that you press and hold the reset button untill the power will be blingking
>>make sure that the router is on when you reset it..
>>we have to consider that maybe its a firmware problem,
>>you can go to homesupport.cisco.com
>>you can download the lastest firmware from the website
>>access the default gateway of the router
>>go to the administration tab and click the firmware upgrade tab
>>browse the file that you download fromt the internet
>>just wait
>>reset the router again
Dec 10, 2010 | Computers & Internet
Hi how can i reset my samsung sch0i910 phone? thank you
Hello there...
Which reset did you mean?
- Soft Reset: Power cycle your handset, no data is missing.
- Hard Reset: Power cycle your handset and erase all data, rollback your device to default state (when you got it first time from the store/factory).
How To:
- Soft Reset: Press the small Reset button on the up side of the handset, near the power button
- Hard Reset:
1) Go to Start Menu >> Settings >> System >> Hard Reset >> Clear Memory >> and follow instruction.
2) or other way is: handset in power off state, push small Reset button near the power button while also pressing End & Call button simultaneously and then follow instruction appears on the screen.
hope that helps... :D
Apr 13, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Can the router reset itself? we had ours working for months with a password and then it was reset to jumpstart p1 , my teenage daughter denies she did it. so can it reset itself?
At worst it could be a hacker or your daughter,sorry
Accepting internet and surfing websites give them oppurtunity to gather and or share your personal info.not good at all but can be protected against and prevented,everday info,phone,power,banks,etc
Dont worry take the precautions and reset it,
yes you can reset this machine yourself
on the back off the unit is a small reset button
hold in until the lights flash and then it will be reset to factory defaults,
you will have to set the intenet up again so have to make sure you have the details available to reestablish connection to the internet
Your ISP will help to reconnect you too....
once rest you can go in to the admin and set a new user and password to stop and unauthrised access or changes in the future,
you can also limit or block site access from here too
all you need is the web address and you can blockit
REMEMBER changes must be in ADMIN MODE for them to be of any use.
The DLINK site is helpful and has online help and a download site for manuals and drivers etc,
Hope this helps Cheers MISTERDJ
PLEASE RATE ME >>>>>>>>>>>>>>>>>>>>
Apr 06, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Samsung Galaxy Y Pro B5510 White Unlocked Touchscreen Qwerty Keyboard Logo
64 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
