Question about Canon imageCLASS MF3010 Laser Multifunction Printer 5252B001AA by C
Error e202 - Canon imageCLASS MF3010 Laser Multifunction Printer 5252B001AA by C
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert
  • 289 Answers
The scanner problem. check the rail/way of scanner
Posted on Apr 15, 2018
Bonjour j'ai une imprimante CANON MF212w quand j'allume, elle affiche un masseage Turn the main power OFF and ON et E202 - 0002 Que ferai-je?
  • Code: E202-0002
  • Description: Contact Sensor HP error, Failure in return
  • Remedy: When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies. (1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor. (2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor. (3) Replace the Contact Sensor. (4) Replace the Main Controller Board.
https://translate.google.com
Code: E202-0002
Description: Erreur de capteur de contact HP, ?chec en retour
Rem?de: Si la m?me erreur se r?p?te plusieurs fois apr?s avoir mis l'appareil hors / sous tension, ex?cutez les actions suivantes. (1) V?rifiez la connexion du c?ble plat entre la carte contr?leur principale (J5) et le capteur de contact. (2) Replacez le c?ble plat entre la carte contr?leur principale (J5) et le capteur de contact. (3) Remplacer le capteur de contact. (4) Remplacez la carte contr?leur principale.
http://printcopy.info/?l=en&mod=erc&brand=Canon&model=MF212w&page=3
Canon MF212w Error Codes List page 3 from 4
Mar 27, 2018 | Canon Office Equipment & Supplies
When i power on my cannon 4412 printer it provide e202-0002 message
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies: ( 1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
Apr 04, 2015 | Cannon Office Equipment & Supplies
Canon inmage class mf3010 E202 service error
E202 CIS Unit home position detection error / homeward reading position error When the same error repeatedly occurs although the power is turned OFF and then ON for several times, execute the following remedies.
(1) Check the connection between the Main Controller PCB and the CIS Unit. (J2)
(2) Replace CIS Unit.
(3) Check the connection between the Main Controller PCB and the Reader Motor (M3). (J11)
(4) Replace the Reader Motor (M3).
(5) Replace the Main Controller PCB.
Mar 27, 2015 | Canon Office Equipment & Supplies
How to solve canon mf 4412 error e202-0002
E202-0002 Contact Sensor HP error, Failure in return When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
Jan 27, 2015 | Canon I-Sensys Mf4410 All-In-One Laser...
MF4410 ERROR CODE E-202-0002
how can i remove this error E202 0002 on mf 4410
May 19, 2012 | Office Equipment & Supplies
Error e202 in canon 6330
E202 That is scan problem scan switch scan motor or may bi image processor board.do not forget to rate solution.by MIAN JEE
Feb 20, 2009 | Canon imageRUNNER 5570 Copier
Canon imageCLASS MF3010 Laser Multifunction Printer 5252B001AA by C Logo
856 people viewed this question
old marine
old marine
