Question about Samsung Office Equipment & Supplies
My printer spoler is not working - Samsung Office Equipment & Supplies
  • 386 Answers
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Posted on Aug 01, 2013
How to replace 3rd brake light asm.in the rear spoler
Verys from make and model.
Some you get from inside the trunk lid
some the red lins will be on with screws
Oct 11, 2014 | Cars & Trucks
Rear.spoler.on.my993carrera.isbent.in.middle.how do you repair it apart.from afrom you one gerry
fiberglass resin build a template for it to set in while hardening, sand primer paint and clearcoat..
Dec 09, 2010 | 1995 Porsche 911
Ayellow light on the front panel is blinking and a message came on that the spoler is not working. What should I do
Remove the cartridges
Clean the contacts on cartridges with lint free cloth ( the golden contacts or electrical contacts )
Install the cartridge back in printer
Disconnect the USB cable of the printer and after 30 seconds re-connect
Click on the link to fix the spooler issue - Spooler Fix utility
I hope this will resolve the issue.
Nov 04, 2010 | HP Deskjet D4260 Printer
WHAT WILL I GONNA DO WHEN MY PRINTER SPOOLER IS
click on start->run and type services.msc
and then look for print spooler service.just click on start service.if it is already started.then stop it and start it again and then restart your computer and it will be fine
Jul 27, 2010 | HP LaserJet 1020 Printer
My HP Printer no longer works on my laptop. What
you did not provided any useful information, what operating system you use, what printer, what connection (usb, paralel, network) and what laptop.
general advice only can be provided then.
if windows of any flavour, disconnect the printer, uninstall all software pertaining to this printer. use ccleaner and clean your harddrive including registry.
check printer on another computer if it works. if printer works correctly, problem is with your laptop, not with printer.
follow this procedure, install software, connect printer, switch printer on, windows will automaticaly install drivers and printer software
if this do not work, you need to check if port used for printer work with other hardware, ie, usb stick, check cable between printer and relevant port.
Jul 20, 2010 | HP Computers & Internet
Printer stopped working. pc sending job to
hhhmmm... maybe you have installed the drivers many times.. the printer shows more copies in the printer panel... you must delete those printers... because that will cause conflict ....
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Printer A920 not working
Make sure the printer is not set to work offline by right clicking the printer under printers in your control panel. If that is not the case make sure that when you are trying to print the printer is setup as the default printer.
Apr 12, 2008 | Dell A920 InkJet Printer
Printing problems
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 10, 2008 | Epson Stylus C60 InkJet Printer
Lexmark 3400
printer screen shows cover open but it is,none buttons will work
Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
105 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
