Question about Vehicle Parts & Accessories
I have the po183 code and I am not getting no fuel I don't hear the fuel pump kick on the car has been sitting for a few years
    New Friend:
Your fuel pump needs to be changed u can try and tap on the gas tank that might work but either way u have to replace it
Posted on Aug 03, 2013
I got a diagnostics reading for my 1996 subaru legacy outback and got codes po183. got any answers for me?
P0183 Subaru - Fuel Temperature Sensor 'A' Circuit High Input ' Add Comment
Possible causes
- Faulty Fuel Temperature Sensor
- Fuel Temperature Sensor harness is open or shorted
- Fuel Temperature Sensor circuit poor electrical connection
What does this mean?
When is the code detected?
An excessively high voltage from the sensor is sent to ECM.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P0183 Subaru Description
The fuel tank temperature sensor is used to detect the fuel temperature inside the fuel tank. The sensor modifies a voltage signal from the ECM. The modified signal returns to the ECM as the fuel temperature input. The sensor uses a thermistor which is sensitive to the change in temperature. The electrical resistance of the thermistor decreases as temperature increase
this sensor is in the fuel tank on the fuel pump assembly. If you look under the carpet behind the rear passenger seat, you should see a sort of rectangular access cover. Underneath this cover is the connector to the fuel pump. Make sure that all looks good. Could just be a bad connection. Sometimes when you have the fuel filter replaced a place will unhook this connector. When it's reconnected it might not be fully seated or have a bent pin or something
http://legacygt.com/forums/showthread.php/code-po183-236198.html?s=4cf7b653edff15233184a4ded52fe754&p=5040847
Apr 11, 2015 | 1996 Subaru Legacy
I have a 1992 chevy lumina Z34 with a 3.4L engine. The car has been sitting for about two years. I replaced the fuel pump, and fuel filter, also I replaced the oil pressure switch but I can't get fuel...
Do you hear the fuel pump switch on when the ignition is turned on by listening at the fuel pump with ignition on you should hear a hissing sound for a few moments and then once the fuel pressure is reached the pump will stop. If not check the electrics and fuses.
Dec 16, 2013 | Cars & Trucks
Chevy colorado 07......fuel pump or fuel pump relay issue?
get a test lite and pull ur relay out and test it if its not lighting up then check your fuel pump
May 29, 2012 | 2007 Chevrolet Colorado (Extended Cab) New...
01 silverado stalls after starting
if you have fuel out of the vacuum connection it would have been a problem pressure regulator
to check for a bad pump , ave fuel pressure test don( 45-65 psi is the ball park figures for most makes )
have the fault codes read to get to the problem rather than wasting money guessing and not fixing
Aug 25, 2017 | 2001 Chevrolet Silverado 1500
How can you tell if the fuel pump is bad
Thanks for choosing FixYa and welcome. The easiest way to tell if it is kicking on is my listening for the sound of the pump. When you first turn the key, you should hear a humming sound for a second or two. This is your fuel pump kicking on. If you don't hear it, it is not kicking on. If so, check your fuel pump fuse, relay, or reset button if you have one. It is possible that the pump works but is just not getting power. You would have to test it from the pump with a voltage meter to know for sure. If you don't hear it kicking on though, it may be bad. If you have cranked it a lot, it might not turn on because the pump is already primed, so let it rest before you try it again.
May 10, 2011 | 1999 Ford Windstar
No fuel to the rail. New pump,filter,control module over radiator(2).checked inertia switch. if wire to inertia switch is same color code as wire leaving ECM then no power leaves ECM when switch is...
It helps if you tell what year,model, engine you are working on. Is power at the Inertia Switch? The power comes from the FUEL PUMP RELAY, the ECM only grounds the relay to turn it on. but not knowing what you are working on, thats all the info I have .
Sep 07, 2010 | Ford Taurus Cars & Trucks
How do I clean my injectors on my 93 caprice.Its been sitting all winter.And I went to start it and it would only keep running with shots of starting fluid.I put stable intank before winter ,but didnt...
Do you hear the fuel pump kick on when you turn your key on? Should be a buzz for about 2 seconds. If you do not hear the fuel pump kick on then try banging on the bottom of the tank with your hand, sometimes that will get the pump to kick back into working again, but know that this trick only works a few times, may be time to replace a fuel pump. The only reason I suggest this is because you stated that it sat all winter. As far as cleaning your injectors-you can pull them out and maybe soak them in a cleaning solvent but i would try to see if your pump is working first. You can also check the schrader valve on the fuel rail to see if you are getting fuel up to the engine.
Mar 20, 2010 | 1994 Chevrolet Caprice Classic
My 92 century 3.3l stalled on way home and i let it sit for about 10 mins and it restarted and I made it home. I replaced fuel pump but the very next day stalled again. what should i do....
did u test the fuel pressure before u installed the pump? it is more likely the crankshaft position sensor on the engine is defective, run a trouble code test and see if u have any codes for thei sensor. Go to this web site to read how to run a trouble code test.
http://check-engine-light-codes.blogspot.com/2006/03/gm-1983-95-vehicles-obd1-codes-self.html
May 13, 2009 | 1992 Buick Century
Cannot seem to get the fuel pump to work a
Yea buddy your fuel pump is gone whether the car is up and driving or sitting for years the fuel pump will give out over time.
Mar 19, 2009 | 1991 Toyota MR2
Vehicle Parts & Accessories Logo
98 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
