Question about Motorola Mobility H680 - Headset - wireless - Bluetooth - black
Blue light not coming on my motorola H680 - Motorola Mobility H680 - Headset - wireless - Bluetooth - black
I have a H680 ear piece newly removed from box.iam unable to charge it although the red light comes on when placed on charger it fades away within seconds have left unit on charger for at least 3 hours but...
James
Sorry you are having an issue. Have you tried another charger? If so and it still doesn't work. CONTACT US . If you have proof of purchase that it was purchased new less than year ago then we'll replace it.
Mark
Motorola Support
Dec 23, 2014 | Motorola Mobility H680 - Headset -...
H680 bluetooth connected but can't talk or hear
Delete the pairing and connect again.
Mark
Motorola Support
Apr 11, 2014 | Motorola Mobility H680 - Headset -...
H685 I lost my pin code to pair it with my phone
The default pin code for the H680 is 0000. (Four Zeros).
For complete instructions, go here. http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/H680/US-EN/_Documents/Static%20Files/H680_QSG.pdf
Nov 10, 2010 | Motorola Mobility H680 - Headset -...
Have Motorola H680 blue tooth hands free transceiver for ear. Need to increase volume and can't find a way to bypass their volume limits
This would have to be a modification or hack which voids your warranty, if you have one. I can't give you information to hack or modify your blue tooth but I can tell you its a service that you would need to have done via the internet or a local friend.
Good luck,
Brandonmxb
Dec 10, 2009 | Motorola Mobility Bluetooth Hands Free...
Pair my h680 to my razr m9c
When you turn your bluetooth on you should press and hold the button and it will flash several times then the light will stay on. On your phone under bluetooth devices select the " find devices" and it should pick it up within a few seconds.
Jun 07, 2009 | Motorola Mobility H680 - Headset -...
I need a pass key for the blue tooth product h680
By Default blue tooth pass keys are 1234 or 0000 hope this helps
May 03, 2009 | Motorola Mobility H680 - Headset -...
Problem w/ connecting h680 to EnV2
just get your bluetooth in pairing mode (steady blue light) then have your phone find the device then connect them when they ask you for the pass code its 0000 if your bluetooth is connected to a different phone you must disconnect it and if it doesnt work and you tried your best try turning the phone off then try it again sometimes this does the trick
Mar 29, 2009 | Motorola Mobility H680 - Headset -...
Motorola h680 has no sound but a flashing red light.
I have same issue, worked perfectly for about year, then all of a sudden when I receives a call I could not ear anything. The other end can ear me, and I can make commands to my phone still but, I hear nothing.
Dec 31, 2008 | Motorola Mobility H680 - Headset -...
Motorola Mobility H680 - Headset  - wireless - Bluetooth - black Logo
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
