Question about Mitsubishi Heating & Cooling
Air conditioner msz-gb50va error code up??? - Mitsubishi Heating & Cooling
4 Suggested Answers
  • 5 Answers
SOURCE: mitsubishi msz-a24yv air conditioner.keeps turning
a/c units have ways of protecting their major components. if you have a freon leak it could be shutting down on low pressure safety switch. or it could be overcharged with freon and be shutting off on high pressure, although high pressure safeties usually have a manual reset. therefore a low pressure
problem is more likely
Posted on Dec 10, 2008
6ylucy
  • 742 Answers
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
Posted on Jun 26, 2010
  • 81 Answers
SOURCE: MSZ-A24NA Split System Air Conditioner: it stopped heating, air comes out but no heat, brr...
Is it defrosting??? Your problem is quite brief and that is the only advice that I can offer based on your question.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
Hey, i have a MSZ-GA80VA and the head unit starts for a few minutes and then stops with the left light blinking. i also noticed that the outside unit does not kick in. Daniel
Is there some error code.? Without knowing error code, chances for yor your problem is:
If indoor working properly, there is communication problem between indoor and out door. Check for power in out door after 3 minutes of a/c switched on. If no power problem with your PCB. Replace it.
Jan 18, 2011 | Mitsubishi Heating & Cooling
I have a error message f1 on my air con
F-1-Noc ommunicationbetween indoor and outdoor.Check connections and LEDs. If OK replace either main or fan PCB
Jan 15, 2011 | Mitsubishi MSZ-A15NA Split System Air...
Mitsubishi msz-ga60va not cooling. Did same last year then righted itself. Left light is flashing. and no cool air. Please help.
You didn't give any error code. But, still, I hope unit need complete service. Do it and check again.
Jan 07, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
How to turn heat on for split system MSZ GE 12NA
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Nov 06, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
May 18, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Heating & Cooling Logo
43 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
