Question about Maytag Dryers
Where are the brushes on maytag motor , dryer , how do you get to them ? Ian.
  • 24 Answers
You don't, there are no serviceable parts on those motors. Years ago those motors were able to be disassembled now they are epoxied together and even if you were able to take them apart you would not be able to get parts for them.
Posted on Aug 01, 2013
Why is dryer making a noise loud and sounds like motor?
U may have a bad bearing going out or the drum roller wheels or pulleys are bad. a bad belt? hopefully its not the motor or windings and brushes going out? Then agin may need to have the tranny looked if its seizing ? sorry lots of different opinions here but it could ba any of the above. is it tunrning ok or is it unbalanced and can u hear the noise from within the dryer if so it may just well be the drum rollers and thats not a difficult or costly job?
Aug 16, 2014 | Maytag Dryers
Why is my maytag dryer making a loud noise when i turn it on?
could be varied issues? bad bearing, bad drum rollers? belt? and last lets hope not bad motor bearing, windings or brushes?
Aug 16, 2014 | Dryers
Maytag washer mhwe300vw13 will not spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Coming the second aspect if the above gives no result:
Perhaps you need new carbons brushes for the motor. It is a fairly straightforward repair. Remove the top cover, screws at rear, and slide top cover off towards the rear. The motor is located at the top right right rear, you will see the drive belt. Slacken the bolt that holds the motor, and push the motor down towards the top of the drum. You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic lug that holds the brushes in place, slide the brushes out of the motor. The length of the brush should be at least half an inch long or replace. Fit new genuine carbon brushes,
and follow instructions on packaging. Push the leads back on to the carbon terminals. tighten up motor, and make sure the belt is reasonably tight. Test on final spin before you refit top cover.
(Spares can easily be located on this very site - Fixya)
There are very gud videos on YouTube to guide you.
If helped pl click so.
Mar 31, 2013 | Maytag Epic Z and Performance Series 2000...
Maytag dryer model #PYE2200AYW how to remove lint compartment once I removed the screws in the front
Instructions
Things You'll Need:
Nylon scrub brush Liquid detergent Vacuum
1.Remove the lint screen, which usually is located in the front of a Maytag dryer. Gently pull it up and out, and remove the lint with your fingers.
2. Use hot water and wet both sides of the lint screen. Use a nylon scrubbing brush and a little bit of liquid dish soap or laundry detergent to scrub the screen clean of lint and fabric softener buildup. Rinse both sides thoroughly with hot water. Towel dry and replace the lint screen when dry. Maytag states that owners should do this every six months.
3.Clean the exhaust every two years, as recommended by Maytag. Whoever installed your dryer had to install the exhaust vent. Unplug your dyer and unscrew the vent from the back of the dryer. Use a vacuum attachment or your hands to remove any clogged lint and replace. You may need to do the same thing to the other end that is attached to the wall.
4.Clean the dryer cabinet. According to Maytag, a professional should remove lint from the dryer cabinet every two years. This may be a good time to have him clean out the vents as well, rather than doing it yourself, if preferred.
5.Clean your lint screen on a regular basis. Maytag states that you should clean the lint screen with your fingers before using the dryer each time. Be sure to replace it all the way so it can work properly.
Mar 10, 2011 | Maytag Dryers
My maytag neptune dryer makes a buzzing sound but does not turn, then later in the day, it will start just fine and run, until later in the night and then it won't . does this mean I have a loose belt?
its either a loose belt, (very easy to sort out as most tumble dryers use the motor on a pivot to tension the belt.)
if its not a loose belt its most likely to be the carbon brushes inside the motor that have worn down and are now making poor contact with the motor itself.
if your not confident to have ago at fixting these yourself, most repair shops should be able to-do this for you in 10 - 20 mins tops and it should not cost a fortune either.
Dec 29, 2009 | GE DBL333EA Electric Dryer
How do I clean out the dryer
remove front / and get yard blower and blow it out . don't you dare . get a shop vac and lint brush and vacuum out . blow out motor after vacuum . clean vent in front . and your done .. replace front and be carefull with the wire to the door sw .. mm
Dec 03, 2009 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer
Two highest probabilities are that the belt is worn and slipping on the motor pully or that the motor is drawing too high of amps, working too hard, wore out. Also if there is excessive lint in the internal air chamber this can also be a problem. To reduce the suction draft of your blower remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not runnig straight through then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. This wont really fix the main condition, but it will not hurt. Remember this tip on future driers and you will make the dryer blower motor last much longer and it will lower your energy consumption.
Jan 27, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer
The secret to great dryer performance is air flow. Fresh air must enter from the rear of the dryer through the vents and exit through the exhaust. If this flow is compromised it will increase the dry times. The length and condition of your exhaust vent would be the first place to check. Some of the industry have said that if you use dryer sheets the lint filter could be plugged from the wax used in dryer sheets. This idea is not industry wide. If your lint filter apears to have a white color across the mesh, then it is plugged. Warm soapy water and a soft brush will clear your filter. Your dryer was designed to have a certain amount of cubic feet per minute of air flow. Anything that changes that will effect your drying cycle time. Lint build up inside the dryer can also restrict air flow. A back up of hot air will cause the thermostats to cycle off prematurely.It can also cause the the drive motor to over heat, the thermal overloads on the drive motor will kick out and keep the dryer from restarting again until the motor cools off. A loud buzzing noise or a lack to start or both can mean a bad motor.
Sep 22, 2008 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
26 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
