Question about Samsung S5830l Galaxy Ace Black Unlocked Gsm 3g 5mp Wifi Android Cell Phone 2gb
Wi-Fi network secured withWPA/WPA2 PSK, cannot unlock
    Problem Solver:
  • 16 Answers
Some passwords have complexity, upper case and lower case sensitive. Input the correct lower case and upper case letters as they are on your router
Posted on Sep 29, 2013
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Tip
How to achieve 300 Mbps speed in N standard routers ?
To achieve 300 Mbps speed in N standard routers:
In order to achieve 300Mbps speed between router and your wireless computer you must have an N standard router from belkin and also the wireless adapter on our computer should be an N standard (802.11n).
If you fulfill the above criteria then you can follow these simple steps to achieve 300Mbps speed between your computer and router.
  • Connect any Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox any of your web browser (chrome will not support).
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Step 1: Wi-Fi Protected Setup (WPS)
In the Belkin router Setup page, on your left hand side, you will have Wi-Fi Protected Setup (WPS) below WIRELESS. Click on Wi-Fi Protected Setup. If it prompts you for a login password, leave it blank and Click on Submit.WPS will be enabled by default. Change it to Disabled and Click on Apply Changes. It may or may not take some time to save the Information and brings you back to the same page.
Step 2: Security
Select Security found on left side of router setup page.Security mode will have the following options,
  • WPA / WPA2 (PSK)
  • 64-bit WEP
  • 128-bit WEP
  • Disabled
Now select this way.....
  • Select the security mode as WPA/WPA2.
  • Select the authentication type as WPA2.
  • Select the encryption type as AES.
Then you will be able to see the pre-shared key (PSK) or passphrase (PSK), in this box you need to type at-least 8 characters as the network password.
After typing the password you can verify the password by un-checking obscure PSK. Password is case sensitive. Once you are done check obscure PSK and Click on Apply Changes.
You need to enter the same password in your computer to get connected to your wireless network.
Step 3: Channel and SSID:
Once you are done with that select Channel and SSID found on the left side of RSP.
Change the Wireless Channel to 1 or 6 or 11 (these are the best non-overlapping channels for wireless networks).
Change the SSID to any name as you wish, this will be your wireless network name (I recommend you to use a single word of any length. It can have letters, numbers or combination of both).
Check whether the option Broadcast SSID is checked / enabled (it must be enabled).
Protected mode should be OFF.
Bandwidth should be selected as 20/40 or 20+40 MHz
Once you are done click on Apply Changes.
Now connect the computer to your wireless network.
It will be connected at a speed of 300Mbps.
click here to know how to connect to the wireless network....
on May 19, 2010 | Computers & Internet
Using my phone as mobile hotspot how do i get my network ssid.
You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select Wireless & networks.
5. Select Tethering & portable hotspot.
6. Select Portable Wi-Fi hotspot checkbox.
7. Select Portable Wi-Fi hotspot settings.
8. Select Configure Wi-Fi hotspot.
9. Input a Network SSID for your connection.
10. Select a security protocol. Options are Open andWPA2 PSK.
If you select WPA2 PSK, input a password for the connection and then select the Save button.
You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
Aug 08, 2014 | Cell Phones
3. Select Settings.
10. Select a security protocol. Options are Open and WPA2 PSK.
-regards and update me
We have a vizio smart tv but cannoy connect yo wifi.What should we do?
Vizio will not connect with Netgear wi fi, BUT if you want to try it, you have to adjust the security
If you have the skilset then..........
Set your router to use both WPA-PSK (TKIP) and WPA2-PSK (AES) and the TV finally connected using the WPA-PSK (TKIP) security!
Mar 06, 2014 | LG Televison & Video
Wifi tethering
steps. Settings > Wireless & networks > More... > Tethering & portable hotspot > Set up Wi-Fi hotspot,(put in my settings - SSID, security "WPA2 PSK", and password)SaveCheck "Portable Wi-Fi hotspot" At this point the hotspot turns on and is discover-able by other devices
Jan 09, 2014 | Samsung Cell Phones
What is the wpa2 key / //
Wi-Fi Protected Access (WPA) and Wi-Fi Protected Access II (WPA2) are two security protocols and security certification programs developed by the Wi-Fi Alliance to secure wireless computer networks.
You need a WPA or WPA2 key to connect your Game console wireless to the wireless accespoint.
May 25, 2011 | Microsoft Video Game Consoles & Games
What is belkin security code(WPA2-PSK(AES)
WPA2-PSK-is a Type of a WI-FI security. AES- the way how the securty code is translated. example: security= genius AES= 7809123456 it means genius is equal to 7809123456(genius=7809123456) if you try to connect to a WI-FI get the security code in a WI-FI owner/creator
Feb 02, 2011 | Nintendo DSi Matte Blue Console
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
Wi-fi take long to connect
You can try reconfiguring your router to WEP security, that should establish a connection quickly.
May 11, 2009 | Computers & Internet
Samsung S5830l Galaxy Ace Black Unlocked Gsm 3g 5mp Wifi Android Cell Phone 2gb Logo
65 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
