Question about Toshiba IK-WB11A Network Camera
Public Address will not view the camera
I can view the camera on the local area netword but not the public network. I have the camera http set to port 5631 and 5631 forwarded to the camera. 5631 is not blocked by the isp or the router.
Re: Public Address will not view the camera
Some DSL lines from the telco will not allow "loopback". Lets say you get an IP of from your DSL connection (may it be dynamic or static). Any computers that are within the same network range of 68.10.10..xx will NOT be able to connect to you. It simplify the explanation, the DSLAM acts like a switch (not a hub) and any traffic behind it is blocked form circulating back. Several times I have customers with offices in different locations, but on the same side of the DSLAM. I had to get the telco change the assigned IP addresses for them to connect to each other. Here at home, I can see my cameras on my LAN, but when I try to see them at my DSL IP, I can' I use my cellphone to connect to the internet and then to my home DSL IP address.
Posted on Sep 17, 2007
  • Toshiba Master
  • 12,061 Answers
This is a common mistake.. ya CANNOT "See" a camera or such, as this, on the "Public" side of things, 'cause ya not... So, UNLESS you go to ANOTHER LOCATION and try, well OK.... & THEN you should be able to View ya camera, if all is well... OR get a 3rd party to check from their PC from their location... The fact ya can see it on ya local network should be encouraging.
Posted on Sep 01, 2007
0 characters
3 Points
I do i get the default username and password for vivotek fd8134 camera
An IP camera is a video camera that can be viewed over a Local Area Network or the Internet. The camera typically is monitored locally from a computer via the network to which the camera is attached. With just a few additional configurations of your network, you can access the IP Network Camera so that it can be monitored remotely using the Internet. This is the benefit of a network camera, as it can reside on an IP network and the video stream can be accessed or saved remotely.
Get the Default Gateway of your IP. step 2 Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yours lf known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it. Hope it helps.
Jan 23, 2013 | Vivotek FD8134 - Network camera - dome -...
VEO observer hard wired version
Did you configure the webcam to be accessible over the internet? The IP address that you are using in your home network for the cam is only valid there (I assume you are running on a workgroup).
Jan 25, 2008 | Veo Wireless Observer Network Camera
I have two Panansonic KX-HCM130 cameras. I have them installed on a Belkin F5D7234-4 V5.5 Belkin router. They can be seen locally on the network with local IP address and
Download and install Webcam 1-2-3 >
or Direct link
To set-up /configure webcam 1-2-3 software for live streaming refer to:
Then follow the instructions from this page -> on how to configure Belkin router for Webcam 1-2-3 . Important! You must have a static IP address .To avoid port conflict, use a port other than 80 for HTTP streaming
And the manual for your Belkin F5D7234-4 router can be found on the link below:
Please let me know if you need further assistance on this issue .
Nov 09, 2011 | Panasonic KX-HCM10 Network Camera
How to install it?
Go to the "Start" menu and "Control Panel" and click on "Device Manager. Proceed to "Imaging Devices" and "HP Webcam."
Click on the "Driver" tab. Update the driver. Click "Search Automatically" for updated driver software.
Open "Quick Play" and click on the music, video and picture icon on the bottom of the screen.
Under "Source" click "USB Video Device." Your webcam should be activated. Press the red button on the bottom of the screen to record video. Press it once more to stop. Click on the camera icon to take a snap shot image.
Go to "Public," "Public Videos" and "HP Webcam" to view your videos. Go to "Public," and "Public Pictures" to view your pictures.
Aug 20, 2010 | HP Webcam
I can not access the setup of my camera trendnet TV-IP110W since Internet Exporer
  1. Please make sure if both the camera and computer is connected to your router's LAN port
  2. Open the IPSetup Software which came on the CD along with the product
  3. It will detect the camera's current IP address. You can change it to an IP address based on your network
  4. The double click on that IP address or type it on IE's address bar. Camera's Live view will be shown up
  5. Then you can match the wireless setting with your wireless router to view the camera wireless without being connected by a Ethernet cable
May 15, 2010 | Trendware TV-IP110W Network Camera
How to connect to remote camera
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Jul 13, 2009 | HP USB Web Camera
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
VeoNetwork Web cam
You can view your Veo Observer web cam at home by either of two methods. The first is to use the Observer Studio software that came with the camera. When you configured the camera, you selected a local (private) IP address for each Veo Observer, and set the address specific to each camera. You then put the same IP address into your Observer Studio Software.
Depending on the brand of router you use on your home network, your Veo Observer camera probably has a local (private) IP address in the format or where "xxx" is the actual address assigned to your Veo Observer (by you) and configured to display on the LCD window on the side of the Veo Observer.
You may need to log into your router to see which of the two local (private) IP address formats is used. Your router's user manual will show you how.
To view your Veo Observer, just type the exact local (private) IP address in your IE browser. for example, if you assigned address 100 to your cam, you would enter or into your browser. Veo Observer will display the Language selection screen. Choose the language, then you log in and view your camera.
To view your camera from outside your home using another computer, you use the same method, but you have to substitute your WAN (public) IP address.
You can log into your router and select its STATUS tab to view your WAN (public) IP address. See you router's set up guide if you do not know how to do this.
An easier way to determine your WAN (public) IP address is to visit Gibson Research Shields Up! web page:
and scroll down to the last paragraph where you will find your WAN (public) IP address.
For example, if this address is 123.456.789.100, then you would enter http://123.456.789.100 on your IE browser. You should see the Language select screen, choose your language, then log in and you are now viewing your Veo Observer from outside your home.
Note: when you view your Veo Observer at home, you probably have a fast frame rate and smooth video motion. When you view your Veo Observer from outside the home, the frame rate is certain to be less, and your moving image quality will be choppy. This is normal, as viewing from outside the home is less efficient and the image suffers. There is nothing you can do to boost the frame rate.
Jun 15, 2008 | Veo Observer Network Camera
Networking the intellinet 503181
There are a couple things to check. Make certain that you have port forwarding enabled for port 80/80 to the IP address of the camera. Make certain that you have port forward for port 8080/0 to the IP address of the camera. Find your IP address for your Internet connection - you can go to and it will display your IP address for you. Then open your browser, type in your Internet IP address on the address line and hit enter. That should bring up the guest log in window and you can log in to view the video stream. If you want to log in to the camera console to change configurations, just type the camera user name and password instead of the guest user name and log in.
Hope this helps!
Dec 31, 2007 | Intellinet Active Networking 550703...
Setting NG
make sure you are using a crossover cable. A straight through ethernet cable will not work for talking with your computer. Next, go to your network connections. click on TCP/IP properties and enter in for the IP address and a subnet mask of apply it. go back to network connections and disable then enable your connection. Now go to the Sony IP setup program. Double click on your camera when it appears. Don't forget the default address of the camera is
Jul 08, 2007 | Sony SNC-RZ30N Network Camera
Toshiba IK-WB11A Network Camera Logo
132 people viewed this question
Top Toshiba Webcams Experts
Are you a Toshiba Webcam Expert? Answer questions, earn points and help others
