Question about Sport & Outdoor - Others
My Agua4fun hot tub keeps flashing on the control board FLC. Could anybody tell me what this means. Paul
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: f08 keeps flashing
probably heater relay cannot be actived, you will need an engineer.
Posted on Nov 18, 2008
SOURCE: anybody please tell me what the yellow light is.
i heard it waz like yellow ring of death
Posted on Jun 29, 2009
KevinWhite
  • 1902 Answers
SOURCE: Can anybody tell me when
Hello & Welcome to FixYa
Why to buy another manufacturer parts if both are available separately, you can buy Hotpoint here and indesit here , anyways both are same you can buy either ones. Please get back to me if you have any other questions.
Kevin
Posted on Jul 02, 2011
  • 111 Answers
SOURCE: My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Posted on Dec 02, 2012
I have a jacuzzi whirlpool modelz145, h240000 it keeps running on low never shuts off this just happened never did this before? Bad control board?
Is this an outdoor hot tub?
If it is an outdoor hot tub...is it heating up or just running all the time?
Sep 21, 2014 | Jacuzzi Home
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My hot tub is cold and the board is flashing hl
when a hot tub flashes a code I have found that 99% of the time it is the the flow switch with tells the mother board that it is ok to turn on the heaters. you need to power tester and check to flow of power to each section on the system. It would help very much if you had a wireing diagrham.
If yo understand power and how it will work a system from the point it ties into the first wire. Take your tester and slowly follow the pathway.
I wish I could paint a better picture where its " just push a button" but I can not.
Best of luck, BE SAFE and dont forget to rate how we helped or hurt you :)
Tom
Sep 10, 2011 | Water Heaters
The panel is flashing a F70 problems what does this mean
Hi, F70 means that the dishwasher senses the motor running even though control board is not telling it too. Here would be the reasons for this 1) There is water in the base pan so it has flooded and is trying to remove any water remaining in the tub. 2) Your control board relay is stuck.
If you want to to check for water in the base, you need to uninstall the unit tip it on it's side and remove the 4 screws on the bottom of the base pan. If you remove the pan and see water you need to determine where it's leaking from. If not you need a new control board.
Jun 28, 2011 | Dishwashers
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
Even thuogh I made sure it was not on economy mode my hot tub will not heat up and the message board keeps flashing the word cool, do you know what could cause this?
it may be a bad temperature sensor or a bad heating element. Sounds more like a heating element. The cool should just be a warning or depending on the model, could mean that it thinks the water is too hot and is in "cool" mode trying to cool the water. Have the temp sensor and the heating element checked.
Feb 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Sport & Outdoor - Others Logo
22 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
