Question about Refrigerators
Hi, what clips do I need to install a fridgemaster mtbcb275 to the cupboard doors and how do I connect them?
What colour can I color my kitchen cabinet doors?
Simply take a little test of the floors with you to Lowe's or House Depot and request somebody in the color department to help you available. Additionally they have a few colour blends that appear to be well-liked with allot of folks. What I am talking about is they have matched sets of colours that combine together therefore all you must do is purchase the color and you know it'll fit. Hope this can help and best of luck. shopfitters
May 22, 2013 | Cars & Trucks
My fridge is too high by 1\8 inch to install it under cupboard
If it is only 1/8".... take a sander and take that much off of the bottom rail of the cabinet so you can get it in there...
heatman101
May 06, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Got one from dollar tree, but the install instructions are confusing. Following is the instruction: << Remove the self-adhesive protective film from the LED light and place it in your...
The magnet needs to be less than about 1/4" from the light when the door is closed to activate the magnetic switch in the light and turn the light off. Fix the light to the frame or wall inside the cupboard and the magnet to the door.
Feb 28, 2011 | Kitchen Appliances - Others
Dishlex global 300 - dish washer door won't open
I have the some problem toooo!!
I have turned it off and on from the power point and run the cycle again on "normal" and on "rinse" .
Next step will be to cut the screws with a hacksaw , remove the the dishwasher from the cupboards, remove the bottom tray and give a good clean underneath .
Feb 08, 2009 | Dishwashers
Place for washing mashine
You do not need airflow for the washing machine only the dryer.
And yes you can put it inside of a cupboard or cabinetry,as long as you have water supply, and waste water discharge access
Jan 19, 2009 | Washing Machines
Door Knob Problem
Usually this is quite an easy problem, just open the cupboard or drawer the knob is connected to, take a star screw driver and tighten the screws of the knob from the inside, this should solve your problem.
Please rate this solution if it helped you,
Thank you,
J.
Aug 27, 2008 | Top Knobs Door Pull - Oil Rubbed Bronze -...
Oven door
Hi thanks for the question. lay the door on the floor .the hinge must be locked before it can be installed back in the oven. each hinge has a locking clip . push down on the hinge and lock with clip . same on the other side. install door. push door down. unlock the clips. close door. to remove door. push door down. lock clips . pull oven door out . thanks the appliance doc
Aug 05, 2008 | Frigidaire FEF366 Electric Kitchen Range
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
