Question about Roundup "" Weed & Grass Killer
How long do i need to allow rosate weedkiller to dry
What is the mixing ratio for ultra max for weed killing?
Hey Richard.. 1 oz. "weedkiller" to a gallon of water...
Jun 23, 2017 | Ultra Max Garden
Weeds weeds weeds & more weeds anyone know a good landscaping forum for weed SOS?????
One years seed, 7 years weed! Use Round Up, Flamethrowers, mechanical tillers, hand tools, just keep attacking them until they give up. Commercially, you can buy 'Total Weedkiller', nothing will grow for 7 years.
Worst stuff i dealt with was Japanese Knotweed in the UK which is a notifiable invasive species. The
local authority was pleased with my ideas, and I won :>)
Apr 01, 2017 | Garden
Glysophate How much to use in 6 litre spray
This depends on the exact product which you bought. It is available from ready-to-use to very concentrated forms, as well presumably in solid (powder or crystals) form. You should follow the instructions on your package. If none are available, dispose of the weedkiller safely (do not pour it down the drain, take it to a garden centre - I would hope that they would not just do the same !!), and buy new. It is a poison !
12.August.2014
Aug 12, 2014 | Garden
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
Resetting
Hello! The vacuum will reset itself, you only need to allow it time to cool off.This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are simple instructions for checking your vacuum for clogs.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Hope this was helpful!
Primary Filter
Exhaust Foam Filter
Mar 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
My neighbor keeps a supply of freeze dried food, but why do you need to stock up on freeze dried food?
No one wants to think about it but you never know. There could be a disaster of some kind that might leave you house bound for a while. Freeze dried food allows you to have emergency supplies to keep you going for a few days just in case!
Aug 13, 2012 | Camping, Backpacking & Hiking
How does one use Rosate 36 weed killer in a 5 litre sprayer? I cannot follow the label as it only applies to fields!!!
The label on the back of the container has 5 pages of information. Pull the right hand side of the label and it opens out. One page of it says 125ml of rosate to 4.88 litres of water for a 5 litre sprayer. I hope this is helpful. J.D
Apr 22, 2010 | Roundup "" Weed & Grass Killer
Roundup "" Weed & Grass Killer Logo
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
