Question about ASUS Eee PC 1201N (EPC1201NPU17BK) Netbook
How to do a hard reset on my asus???? - ASUS Eee PC 1201N (EPC1201NPU17BK) Netbook
    New Friend:
  • 157 Answers
You need to go into the bios settings and boot windows dvd from dvd ROM then you need to do partition. This is how your hard drive will reset.
Posted on Aug 01, 2013
Reset asus memo pad kow to factory settings?
If you cant reset your phone normally try hard resetting it.
  1. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  2. Afterwards unzip it to your MicroSD card.
  3. In order to turn the device off press the Power button for a short while.
  4. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  5. Afterwards unzip it to your MicroSD card.
  6. In order to turn the device off press the Power button for a short while.
  7. Select Clear User Data using the Volume buttons to navigate and Power key to select.
  8. When "Please remove installation media!" inforamtion appears on the screen remove the microSD card from your device.
  9. Success! The hard reset has just been performed.
If this doesn't work use the link below
ASUS ME176C Memo Pad 7 How to Hard Reset my phone HardReset info
Mar 17, 2017 | ASUS Tablets & eReaders
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Reset ep121 asus tablet
http://www.technipages.com/how-to-soft-and-hard-reset-asus-eee-pad-transformer
Dec 04, 2015 | ASUS Eee Slate EP121 Touch
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My Asus phablet keeps shutting down how do I fix it
Did you recently update or install a new app? This could be causing issues. Try a hard reset or you could try a factory reset but you'll want to have backed up your data - hopefully you did this already. http://www.asus.com/support/FAQ/1006133 http://www.asus.com/support/FAQ/1006133
Dec 17, 2014 | ASUS Computers & Internet
How do I reset?
find a pinhole on the side and insert a paperclip and press for about 3 minutes.
Jun 21, 2014 | ASUS MeMO Pad HD 7
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Mar 05, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Hard reset
A hard reset, or recovery, is done by pressing F9 at startup (asus logo).
Aug 01, 2013 | ASUS Eee PC 1201N (1201NPU17SL) Netbook
I have recently changed my screen locking password to some alphabetical password from numeric password and now its locked and not giving option of any alphabet and my screen is locked i tried reset button...
hi sandy that thing is happen frequent in ASUS P527. the easies way to solve that problem is to do a hard reset. to perform a hard reset, push the toggle key upward which is on the left side and don't release it, now by using the stylus push the reset button.... there you go :-)
asang
Jul 01, 2011 | ASUS P527 Smartphone
ASUS Eee PC 1201N (EPC1201NPU17BK) Netbook Logo
188 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
