Sony rm gd001 channel button does not work - Televison & Video
3 Suggested Answers
panzrwagn
  • 13 Answers
SOURCE: RM-AV2100
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Posted on Dec 14, 2007
gopakumarg43
  • 74666 Answers
SOURCE: Sony remote control GD001 - volume control doesn't work
Your remote control need cleaning.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 700 posts to different brand TVs now.
Pull up older posts there. Cleaning procedure to remote control is given in detail.
Posted on Sep 11, 2012
Remote Control Manual for Sony RMF-GD001
This just happened to me... the remote stopped operating the TV. Using the touch buttons on the front of the TV I deleted and re-registered the remote. All OK
Sep 25, 2013 | Televison & Video
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Sep 10, 2012 | Sony Televison & Video
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
My RMF-GD001 operates everything except the tv. I own a Sony Bravia XBR46-45 tv connected to a sony surround sound system
I had the same problem.
My Bravia LCD TV wasn't responding to its remote RMF-GD001 although the remote works on the home entertainment unit. Lucky for me, I have an extended warranty and so I called for a service. Technician tested my remote and said that it's RF transmitter is spoilt. Little did I know that the remote has IR and RF transmitter and it will work on any devices that uses infra red transmission. But Bravia LCD TVs use the radio frequency transmission and that is where the problem is.
I had my $125 remote replaced FOC. :)
This reminds me to get a silicon case for the remote and to put it out of reach from my kids who like to drop things.
Oct 18, 2011 | Sony Televison & Video
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
RM-AV2100
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
