Question about Kenwood ProTalk UBZ-LF14 (14 Channels) 2-Way Radio
My ubz-lf14 cannot turn on,if turn on,can only hear but cannot reply ptt,then turn off automatic..why this happen?what I can do DIY for solve this thing?
3 Suggested Answers
vrc_tech
  • 109 Answers
SOURCE: I need help
This sounds like one of those situations where the radios will need to be serviced at a local kenwood dealer or depending on the value of the radios you might want to junk them. The average radio repair runs $75.00 to $90.00 just for the labor. The other option if so inclinded to do so would be too order the service manual for this radio and attempt to complete the repair yourself. I don't know your skill level at electronics. I wish I could help you more.
Patrick
Posted on Dec 11, 2008
  • 19 Answers
SOURCE: Need owners manual
Hello there, I think your best bet would be to contact kenwood customer support/distribution Fax (310) 537-8235 for your manual, or they will advise what path in their division to take l'm sure,
good luck --John.
Posted on Apr 24, 2009
How many miles will the Kenwood UBZ-AR14 transmit?
Two miles under perfect conditions over flat clear terrain.
Aug 06, 2014 | Kenwood FreeTalk UBZ-LH14 (14 Channels)...
Headset transmits automaticly
Your headset is operating in VOX mode. This sometimes will happen if the headset is plugged into the radio when the radio is still turned on. Try unplugging the headset, turn on the radio, then talk using the PTT on the radio. Shut the radio back off. Then insert your headset plug, being certain it is seated (click) into place. Then turn the radio back on and see if it works without VOX. If you are still having problems, press the PTT on the radio one more time and see if it shuts it off.
Mar 12, 2014 | Motorola HMN9021A Dual...
When docking the headset cobra road trip and activate the ptt who hear me get a ring
  • Hi, I can help. When the microphone/earphone set is inserted in the radio itself the control is automatically turned over to the headset. There are no radio adjustment that need to be done. Just plug it in and use the PTT on the cord of the headset or unplug and use the controls on the radio itself.
  • Many don't know that the Cobra Road Trip and the Cobra HH 38WXST are identical radios. The only difference is the antenna sold with the two radios. The one you have come with a rubber duck style antenna and the HH38 WXST comes with a magnetic car mount antenna. So while the manualfor the Road Trip is hard to find the 38 WXST is not. Here is a copy of the manual http://minus.com/mTQOgU0yw
  • Read through the manual a couple times and feel free to get back to me with any questions you have.
  • Hope this helps.
Oct 28, 2011 | Cobra Road Trip 40-Channels Handheld CB...
Cant hear talking with ear peice but I can hear the beep from the radio and the PTT works on the earpeice but thats it.
Check to be sure the earpiece is recommended for your type of radio. Be certain to have the radio turned off when plugging in the audio device. Then check you have the device plugged in all the way. You should feel a slight click when it is seated properly. Use the in-line-PTT only, not the PTT on the radio if this is the method you are want to consistently use.
Aug 31, 2009 | Motorola T7100 2-Way Radio
When I turn on the radio the indicator light on the top of the unit just flashes. I cannot set the frequency or code. When I push the monitor button I hear static but otherwise the radio is dead.
The flashing light can be an indication there is activity on the frequency the radio is set to. Pressing the monitor button should give you the white noise (static) sound, so this function is working correctly. This also tells us your speaker is working fine, as well as your volume. The typical reason you cannot go into programming mode (when you hold the PTT in while turning on the radio and hear the female voice announce your frequency) is a bad or moved internal PTT switch. This typically happens over time as a user presses ever harder on the PTT to communicate. However, this does not explain why you are not receiving. This could simply be a result of an incorrect PL code in conjunction with the bad PTT. If you have a frame removal tool, you can extract the component board and physically look at the internal PTT. You can then hold in the very small button and program the radio to the frequency/PL you desire. If you are needing the radio repaired, you can get this style unit repaired for around $69 flat rate
Jul 16, 2009 | Motorola MU24CVS UHF (4 Channels) 2-Way...
Need owners manual
good luck --John.
Apr 24, 2009 | Kenwood PB-K1, ,UBZ-LG9,UBZ-LG11,UBZ-LF14,...
My Nokia 6600 fold phone wont answer automatically on hands free.
EH?
I KNOW THAT NOKIA 6600 DOES NOT HAVE push to talk or (PTT)
thanks for that question.....
Feb 13, 2009 | Nokia 6600
I need help
Patrick
Dec 10, 2008 | Kenwood ProTalk UBZ-LF14 (14 Channels)...
RECHARGEABLE BATTERY IS NOT HOLDING A RECHARGE
This sounds like you have a battery that has gone bad. If this is the case then it is possible that your local dealership can sell you a new battery. If they can't then try searching for the battery number on ebay or another website that sells batteries.
Patrick
Nov 20, 2008 | Kenwood ProTalk UBZ-LF14 (14 Channels)...
I NEED TO UNLOCK MY KENWOOD 2 WAY RADIO, I WILL PAY
Hello Jack. To unlock your radio:
turn power off
while pressing the mode key, turn the power back on
I also left you a voice mail on your cell phone with this solution.
Dean
Rollin CBs
Jan 27, 2008 | Kenwood ProTalk UBZ-LF14 (14 Channels)...
Radio Communications Logo
48 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
