Question about Cuisinart DGB-600 Coffee Maker
Water leaking water is leaking from the base of the unit, not all of it, but more and more daily. I tried to make smaller quantities, but it still leaks
  • 5 more comments
  • Clymber Nov 25, 2007
    My Cuisinart DGB-600 has started to leak about 1/3rd of the water. This
    has occurred twice so far. The water is cold so it didn't occur during
    brewing. I think it's leaking slowly overnight from the water
    container. I'm going to put a pan underneath, refill it and see what
    happens during the day. I've had this coffee maker for less than two
    years. For the price you would think that Cuisinart would make better
    products. If this is leaking from a crack, I certainly would not buy
    another Cuisinart.
  • Anonymous Dec 11, 2007
    We're having the same problem..shortly after purchasing, we noticed a puddle of water around the base of the coffee first we thought we were not careful during the adding water process..but now we know, it wasn't's coming from the base itself. THe coffee maker is great..brews fast and the coffee is terrific..we just can't seem to solve the leakage problem..NOTE: Not all of the water leaks out..I'd say maybe 1/4 cup of clear water will be found on the counter, just before switching the ON lever..??? clueless here...
  • CCTEX Dec 15, 2007
    Water leaks from crack in heater tube. Where can I get a new heater tube?
  • Anonymous Jan 21, 2008
    I've had mine for over 4 years now and started having the same problem about 6 months ago. I'm just not leaving water in it overnight, however still leaks a bit when making coffee.
  • Anonymous Feb 03, 2008
    I've had my coffee maker for almost 3 years and it started to leak a little during brewing. I found that it's coming from the area that the grinder sits in. I'm not sure if it's condensation. I put a paper towel folded, behind the carafe' in the back, and it catches any water and has stopped leakiing.
  • Anonymous Mar 16, 2008
    Consistently leaks water after every brew cycle. It comes from just under the grinder down the back wall. Very annoying for the price of the unit.
  • ek0923 Feb 10, 2009
    I have a Cuisnart DGB600-BC coffer maker about 3 years old and Water leaks from crack in heater tube. has anyone found a place to get a new heater tube? Please help.
    Problem Solver:
  • 6 Answers
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great! But I must say that i have seen better engineering in child's toys!
Posted on Aug 12, 2008
My car has had a new water pump and thermostat housing unit but still loosing water daily, why?
water has to be going somewhere. have you checked underneath the car and looked for leaks,has to be one somewhere and if you can see or find one it could very well be leaking in the heater core that is located in side the car. one way of telling if it is the heater core is to fill carpet on floor up under the dash to see if it is wet. could also be in the head itself. many things it could be but shouldnt be that hard to track down...hope this helps some and good luck.
Aug 13, 2012 | Ford Fiesta Cars & Trucks
How to clean sunbeam humidifier swm5250
The following maintenance procedures must be routinely followed in order to ensure proper, efficient operation of your humidifier. The unit WILL NOT WORK CORRECTLY if it is not cleaned properly.
When the unit is in use, daily and weekly maintenance is recommended. Regular weekly cleaning prevents scale buildup on the heating element and base. It also prevents micro-organisms from growing on the base. This ensures that maximum efficiency will be achieved.
We cannot over-emphasize how essential proper cleaning is to the maintenance and continued use of your unit and to the the avoidance of algae or bacteria build-up.
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (O) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base and place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is cleaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element clean with a soft cloth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier. DO NOT use any metal or hard objects to clean the Heating Element. Never use detergents, gasoline, kerosene, glass cleaner, furniture polish, paint thinner or other household solvents to clean any part of the humidifier.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the tray by partially filling the base with one 8 oz. cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a cloth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
Disinfect Tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet all surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until the bleach smell is gone. Dry with a clean cloth of paper towel.
4. Refill the water tank with cool water; replace the housing and water tank. Repeal ALL Operating Instructions.
Jan 22, 2012 | Sunbeam Humidifiers
It keeps leaking water, and we cannot determine from what source..It will run for a while and then there is water all over the floor..We do not overfill.
Water is a normal by product of the air conditioning process. Window units must slope downwards, outside. Inside units collect the water in a tray that needs to be drained, manually.
The source of the water is condensation, like the water that forms on the outside of a glass of ice water. Actually, the removal of moisture helps in comfort. Water quantity will vary based on relative humidity....
Jun 30, 2011 | Heating & Cooling
Hello I have just purchased a secondhand hotpoint MAC 130 airconditioner and it is running well however water is dripping from a black outlet at its base. Should there be a hose which attaches/srews onto...
The bigger hole is a drain plug to quickly empty the unit, it should have a runner bung plug and shouldn't leak, the small tube is all you need to get excess water outside
Feb 03, 2011 | Heating & Cooling
Water leak on the left side of the unit
Yes super heat will work. These systems do not have a "liquid line" BOTH LINES ARE ON THE EVAPORATOR SIDE.the smaller line needs to be insulated also. to check subcooling open the condensing unit.
Aug 03, 2009 | GE Quiet-Aire Ductless Split System Air...
Radiator water loss
heat temperature evaporates water, therefore the water level will decrease on a more than daily basis as the vehicle is used. This is just one of the reasons for water loss (or usage). The radiotor drain plug migh be loose or worn. the plug is a white plastic like bolt on the base side of the radiator. Some hoses may be loose, worn or broken. the radiator itself may have a leak somewhere within the accordions. pour in some radiator stop leak.
also try coolant instead of water; coolant has a less evaporative density than water.
Apr 17, 2009 | 2003 Mitsubishi Outlander
Very little water left/ fills up and leaks
**With the unit unplugged**
the float sensor is probably getting sticky with residue and buildup (lime, grime, etc). Try cleaning the little float and that area. It should move easily when clean.
Mar 30, 2008 | Crane Hello Kitty Humidifier
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Shots are small, and water leaks from bottom of unit
You machine has an internal leak and this is why you shots were getting smaller and smaller. The more time goes by the more it leaks, hense, the reason for smaller shots.
You should have someone look at your machine.
Saeco Service Center for New York
Nov 21, 2007 | Gaggia Syncrony Espresso Machine
Cuisinart DGB-600 Coffee Maker Logo
1,133 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
