Question about Car Audio & Video
I have a Citroen C3 car which had some problems with the computer. Now, a garage replaced the ECU/BSI complete with matching transponder immobiliser keys. The car is back working! But the car radio beeps, probably a problem with the VIN number. I visited Citroen garage and they checked with a Lexia computer the radio: VIN number of my car matched with the VIN number that was programmed in the radio. Keeps beeping. Could it be that the car radio is trying to match the original VIN code with the VIN code that is in the s/h BSI? Is it possible that all the other stuff is working then? I have the VIN of the s/h BSI. Could I programme that one via Lexia in the car radio? Thank you!!
rulds2008
  • 3866 Answers
SOURCE: looking for wiring color match shematic diagram for car audio...
http://www.modifiedlife.com/request-a-nissan-car-radio-stereo-wiring-diagram/
Here you go hope this helps you out!!
Thanks
Posted on Jul 18, 2009
etirbynnor
  • 655 Answers
SOURCE: suburu radio wire harness. trying to match up with
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Posted on Aug 14, 2009
emissionwiz
  • 77499 Answers
SOURCE: need a wireing diagramfor toyota camry 95 for car
1995 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: Black/Red
Radio Amp Trigger Wire: None
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Posted on May 05, 2010
  • 4889 Answers
SOURCE: Citroen/Blaupunkt radio unlocked but won't stop beeping
VIN coded radio.
Radio will require coding to your car`s management+security system.
Contact your Citroen Dealer or Radio Decoding Business
Posted on May 29, 2010
J-Chris Ward
  • 731 Answers
SOURCE: trying to install new stereo, wiring colors dont
Hi :) There is no name of radio or vichicle here but here is an good site to find answers obout car audio wiring.
http://www.modifiedlife.com/car-stereo-wiring-diagrams-and-car-radio-wiring-diagrams/
Posted on Mar 19, 2011
I have citroen c3 diesel 2004 model,bought secondhand ignition and put it in and they reprogram it so it start but the central locking dont work,can you assist me please
sounds like the module/ecu for the c/locking is not compatable with the key/ignition.
you're gonna have to go back to the reprogrammer & see if they can match the cl to the ignition.
May 19, 2017 | Citroen Cars & Trucks
Why is water getting into the engine ECU. On my Citroen C3 1.1
in the cab ECU, the window leaks (or door leaks if close to ECU)
under hood, driving too fast in deep water . or horrific fender rust.
you never stated a year, how are we going to guess that.
each generation of car the move the thing... (forward)
May 26, 2014 | Citroen C Cars & Trucks
Citroen c3 stop durin the drive
Ecu issue.?
thats the computer in the car.
Apr 15, 2013 | 2006 Citroen C3 1.4i
Citroen c3 stood on an incline for 1 hour now wont start
You may need a reset of the immobiliser..you do this by pressing the alarm arm button while strating the engine.
May 11, 2012 | 2005 Citroen C3 1.4
I really need help with this car im completely stumped, ive got a 1999 holden VT commodore it has a new standard 3.6L V6 fitted, its been lowered proffesionally, has high flow extractors, a 2 and half inch...
OK mate, see if we can get this sorted.....
When was the 3.6L V6 (I'm guessing an LY7) motor fitted to your VT and has it been running OK or has it always had this fault since being fitted?
400 codes from the ECU rings alarm bells that there is a compatibility problem with either the scantool and the ECU or the ECU and the engine.
OR
I have struck issues in the past where all sorts of wierd things like you describe have been happening and it has been a poor earth to either the ECU or the engine block. (poor earths cause a LOT of problems and really random ones)
Transponder fault does not make alot of sense as it is only going to cause issues on startup, not once the engine is running.
I see the exhaust has been modified...are the factory Oxygen sensors for the 3.6L V6 fitted?
If you can give me some history of the repower ie: who did it, are the engine and ECU matched, where did the motor come from etc. It may give some more clues.
Regards
GeckoNZ
Aug 23, 2010 | 1999 Chevrolet S-10 Pickup
2001 daewoo lanos immobiliser problem car wont start. entered radio security code. immobiliser dash light is still on.
Radio code has no bearing on the immobiliser at all.
Normally it is down to the key not recognised. Are you using the same / usual key as before? If not then try original or another key as it may be the transponder in the key you are using.
If same key or no joy then remove the lower Black plastic steering cowls on the column (normally 3 or 4 screws) you will expose the barrell assy, on the end of this you'll see the transponder pick up ring. Disconnect from loom, apply silicone grease to pins and reconnect then try starting.
If still no joy, disconnect positive terminal off the battery, touch the lead to an earth point for 2 to 3 seconds to defuse and reset ECU, reconnect and try again.
If still noy joy you will need a garage as special reading equipment is required.
Regards
Lloyd
Aug 21, 2010 | 2001 Daewoo Lanos
406 Peugeot fuel pump - Diesel
yes the control pad and the engine management are connected via a unit called the BSI this very expensive to replace around the $1500 AU price so you don't want to replace it if you dont have to the 406 had problems with immobilisers ecu which is able to be unpluged, most of the time this will solve the problem.
if need be tow the car to the dealer and ask them to unplug the imobiliser
Sep 09, 2008 | 1989 Peugeot 405
Citroen zx immobiliser 1400cc petrol 1996
hi i am a mechanic and i have read your problem i think it might be your EARTH STRAP
Jul 11, 2008 | Peugeot 505 Cars & Trucks
Coil / capacitor?
Could be a problem with the reader coil for your transponder immobiliser. The Corrado's ignition key has a transponder chip inside it which is matched to the ECU. There is a small coil inside the ignition which reads the code from the key. These quite often go faulty.
You can find further info on the Corrado Form. www.the-corrado.net
Jun 11, 2008 | 1994 Volkswagen Corrado
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
