Question about Dual XPA4100 4-Channel 600 Watt Car Amplifier XPA-4100
Connot find a wire to use as a remote for the amp in my 1998 subaru forrester
  • Dual Master
  • 636 Answers
I suggest fundfor ng a switched wire in fuse panel if you dint have aftermarket head unit. A power antenna wire wull not power up an amp if you are using cd player or usb
A thumbs up would be greatly appreciated if this answer is helpful to you.
Posted on Dec 18, 2014
  • FastHarley
    FastHarley Dec 18, 2014
    find a switched wire that's controlled by ignition.
    Problem Solver:
  • 13 Answers
Bit stumped!!what wire exactly are you looking for?
Posted on Sep 19, 2013
What causes the Subaru forester to stop firing from the coil pack to the plugs on other pots?
On the Forrester it could be the coil wire, swap the suspect cylinder wire with a good one or temp with one that is firing, if it switches to the other cylinder then u know your wire is bad, if not the coil needs to be replaced. BTW if its been runing a while like that be sure to check the sparg plug and clean it up as its probably fouled now
Oct 09, 2014 | Cars & Trucks
What can make my 1998 Subaru Forrester engine unlock,the engine will not turn but the battery is good
check for a broken timing belt as the valves may be blocking the engine . Remove the spark plugs in case a cylinder is full of water /fuel and is in hydraulic lock. Check oil level as it may have seized the engine.
Mar 21, 2014 | Subaru Forester Cars & Trucks
Replacing front shocks on a subaru forrester 06 model
go to www.automecanico.com and translate the website amazing with your browser and fix it.
God bless you
Jul 08, 2013 | Cars & Trucks
I know where the sensor 2 is but where is the bank 1 for my 1999 subaru forrester code PO 141 O2 sensor heater bank1 sensor 2?
For 1999 Subaru Truck Forester AWD 2.5L MFI 4cyl the Oxygen Sensor is located under hood, center, rear engine area, mounted on catalytic converter.
Fig. Oxygen sensor location-Forester 1998-2002 2.5L SOHC engine (click over image for zoom).
Generally, Bank 1 is front and Bank 2 is rear.
Hope helps.
Apr 14, 2011 | 1999 Subaru Forester
How much should it cost to replace my 1998 forrester belts?
For timing belts $100-200 plus the cost of the belts.
Feb 08, 2011 | 1998 Subaru Forester
I need a diagram for a ting belt on a 1998 subaru forrester.
2.5 DOHC
Route belt in sequence as shown in red after engaging crank pulley.
Count the amount of teeth between the marks as shown in blue:
i - 28
ii - 54.5
iii - 51
iv - 28
RI - Right Intake
RE - Right Exhaust
LI - Left Intake
LE - Left Exhaust
Dec 10, 2010 | Subaru Forester Cars & Trucks
My wife has a 1998 Subaru Forrester. Today we changed the battery. Now, the hazard lights will not go off. Why, and how do I fix this issue?
Under dash by left knee is a 4" x4" box with a small wire on it. On the end of the wire is a small button. Push the button to reset. That sure cure your flashing marker lights. Good luck and have a great day.
Mar 14, 2010 | 1998 Subaru Forester
For 2001 Forrester Subaru - Front Windshield Washer fuse
If it makes noise, it's not the fuse. Most likely the discharge nozzles are stopped up. Try blowing compressed air into them from the outside.
Dec 19, 2009 | 2001 Subaru Forester
Dual XPA4100 4-Channel 600 Watt Car Amplifier XPA-4100 Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
