I have this monitor: L192 Wide (1440x900@60Hz) My computer says I have this monitor: Monitor Name: Plug and Play Monitor Display Type: Analog Gamma Value: 2.20 Nothing I do makes my pc see the correct monitor and something I did changed the onscreen display to Chinese...please someone help me..
SOURCE: PC Freezes when a USB drive is connected
first cheak your USB to the other computer
then see your leptop have some problem or in your USB
SOURCE: I have one monitor connected but under the display
It seems like you have the newer system board with digital output. the machine enable you connect 2 monitors if you want.
default monitor is 2. that's why you can change the resolution and other setting.
the setting will not affect what you going to do. just leave it alone.
SOURCE: My monitor displays no signal
Hi! In your case, if you already check all the connections, the problem is in the display card adapter pls check your VIDEO card if its properly inserted, if it does. Then you have a defective video card. GOOD LUCK thanks
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
