Ba falcon ute bad radio reception
How can i improve radio reception? the car has no tint
SOURCE: bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Posted on Jun 30, 2009
  • 12 Answers
SOURCE: Specs for BA XR8 Ute head
If you are talking about the cam brg caps, they are 10nm. I would be very careful when doing this, as the bolts must be torqued down in order. The sequence is too complicated to go into here. I would strenuously suggest you pay the $50 and buy a shop manual.
Posted on Aug 22, 2009
housejess
  • 317 Answers
SOURCE: bad reception fm radio signal
usually batteries...am takes less juice.....battery strength will affect fm signal strength
Posted on Nov 08, 2009
  • 3230 Answers
SOURCE: improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Posted on Dec 29, 2009
  • 24 Answers
SOURCE: need a diagram to change rear wheel bearings
if you are looking for a manual for this car, try this link... http://cgi.ebay.ph/Ford-Falcon-Ute-BA-series-Repair-Manual-2002-2005-on-CD_W0QQitemZ170423275380QQcmdZViewItemQQptZAU_Clothing_Merchandise_Media?hash=item27ae04cf74 For twenty bucks you can do it all yourself
Posted on Feb 05, 2010
Will a ba falcon sedan right front door glass fit a ba falcon ute
as the cars are BA models then anything forward of the door pillar lock will fit as they are both the same body parts
Jan 01, 2017 | Cars & Trucks
Need fuse diagram for ba?
Howdy howdy John Mullins,
Thanks for adding the 2003 CLUE... that verified what I was suspecting: I am guessing the "BA" FORD nomenclature is pretty obscure ... I had to LOOK that part up... also "Utes"... Cute!
Now I am understanding "BA" to be a series of "Falcon" Fords
indigenous to DOWN UNDER typically between 2002 and 2005
(or 2003 to 2008... else where on the internet).
Being a life long FORD owner... I can tell you for certain FORD Factory manuals were/are available from the dealers... Being old fashioned... I like the hard copies (and have too many cars not to be self reliant)... and they all have the wiring diagrams, circuit drawings... schematics FOR SURE (Volume 3 of 3 on my '04 Navigator & Volume 3 of 5 on my '75 Ranchero).
You are going to like the last (Cabulture AU, local) option the best... eBay.
Ford Falcon BA
Ford LTD BA Service Manual Download pdf
http://manuals43.hobsonjuiceplus.com/manual-ba-ford-v8-2003-yskfqvy.pdf
2003 BA FORD workshop MANUALS
FORD FAIRLANE GHIA BA 2003 2005 WORKSHOP MANUAL All Manuals 12
1974 FORD CAR LINCOLN MERCURY TORINO RANCHERO OEM SERVICE SHOP REPAIR...
Mar 11, 2016 | Cars & Trucks
How do I adjust ba falcon ute door catch
it is adjusted by adjusting the catch position on the door pillar.
Dec 19, 2014 | Cars & Trucks
Ba v8 falcon ute missing and stalling at idle like flooding runs well over 2000 rpm
timing belt may need to be tighten,need to check valve tappet clearance,set perfect timing,clean all sensors in manifolds
Mar 01, 2012 | 2005 Ford Falcon 4.0
Need a diagram to change rear wheel bearings ford falcon ba ute
Feb 05, 2010 | 1999 Ford Taurus
Problems with static
We doubt there is anything wrong with the wiring in your radio. It has been our experience that after market window tint can cause static and poor reception in vehicles that have radio antennas built into the rear window. Removing the tint improves the radio reception but still leaves something to be desired, especially on AM.
May 15, 2008 | 2007 Mercedes-Benz C230 Sedan
78 people viewed this question
 Grubhead
Grubhead
