Question about Stanton T52 Turntable
Stanton T52 Turntable fast
3 Suggested Answers
SOURCE: my stanton t50 turntable plays too fast even when
change the motor is on bad conditions
Posted on Oct 22, 2009
jwdean76
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Posted on Jan 10, 2015
Stanton T52 turntable static
Tricky. I would suggest running a wire to a earth point such as a copper pipe, say of a radiator. A lot of static could be caused by yourself when handling an record. Some carpets make this worse. You can get an anti-static earth strap for yourself, when you handle the records.
http://www.amazon.co.uk/s/ref=nb_sb_ss_c_0_7?url=search-alias%3Delectronics&field-keywords=anti+static+wrist+strap&sprefix=Static+%2Caps%2C177
Feb 22, 2015 | Stanton T52 Turntable
Stanton T52 Turntable. I get intermittent, loud popping, like static. I have checked ground wire, and it is hooked up to receiver just fine. I have cleaned my LPs in every way possible and have tried 3...
There are 3 possibilities I believe here. First a faulty connection to the cartridge or the cartridge itself. (2) internal (inside the deck) fault on a pre-amp. (3) Fault on the magnetic cartridge pre-amp in your amplifier. This would not effect any other functions on the amp.
I have a Stanton turntable, model T52. I think that the internal fuse or the transformer has blown. How do I check to see if it is the transformer or the fuse or both? There is no power getting to the
I cannot view any more information in your initial post after
There is no power getting to the except that you think the fuse is intact. From my experience, there is no transformer driving the turntable motor since these operate directly from the power mains. Can you show us a picture? Dave
Dec 21, 2014 | Stanton T.50 Turntable
Need a new belt
The best I can suggest is that you measure the diameter of the belt in mm and put that into google search with the words "turntable drive belt". Hopefully something should come up! I would suggest contacting Stanton, but I couldn't find the website for the company, so that might be a waste of time, but if you want to try have a go!
Feb 08, 2014 | Stanton T52 Turntable
Internal fuse
Unfortunately, there can be too many causes for this. For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 27, 2013 | Stanton T52 Turntable
Request no:173449ayaij
Have a look under the turntable to see if you can find a speed preset. You can adjust them with a screwdriver. They might be covered up with a sticker. Often there are two one for 33 and one for 45.
Feb 05, 2013 | Stanton T52 Turntable
Stanton Turntable Problem with receiver/audio
You need a turntable pre-amp, or a receiver with turntable inputs.. The turntable is functioning properly, until recently no turntable had this built-in. Search ebay for turntable pre-amp and you should be good.
Oct 04, 2009 | Audio Players & Recorders
Low audio
Make sure it's plugged into the PHONO section. There's a good reason they label it for that - only Phono requires PRE-amplification to boost the tiny signal from the cartridge to a suitable level for the following stages to use.
Apr 04, 2009 | Stanton T.90USB Turntable
Stanton T52 Turntable Logo
46 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
