Question about Seagate ST3500601XS-RK 500 GB SATA II Hard Drive
Device is recognized
Drive was purs=chased in Nov but not installed until May. I have been using it to store my music and pictures, it worked fine until approx 18 July. Since then it will not connect. It lights up put you can not feel it running. I have done the troubleshooting recommended by windows with no relief. I have over 350GB of music and pictures stored to this drive that I can't use. HELP!!!! This device cannot start. (Code 10) Click Troubleshoot to start the troubleshooter for this device.
  • 1 more comment
  • Booklady28 Sep 02, 2007
    How would SeaTools or GetDataRightwork when the drive doesn't even engage to even do a diagnostic/file recovery?
    Since I have a warranty on the drive can IO just let Seagate replace the drive?
    The biggest problem that I have is all the music and picture i have stord on it.
    Will they recover my files?
    I'm really disappointed because Seagate comes highly recommended!!!
  • Booklady28 Sep 04, 2007
    I spoke to Seagate's customer service today, I have a warranty so the drive will be replaced. I have to call the warrant office tomorrow about the Data recovery issue. Even if the drive is not running will How would SeaTools or GetDataRight....." work on that?
    Another ? I'm looking at getting the Maxtor 750 GB drive now as Storage any comments?
  • Booklady28 Sep 05, 2007
    I have a copy of seaTools but it says I need .net framework 2.0 or higher but I have no idea what version to download. Can you help, I'm running XP with service pack2.
    Problem Solver:
  • 16 Answers
"It lights up put you can not feel it running." u cannot feel it running.. it means that its pcb is damaged or the motor has damaged.. there is nothing u can do with the softwares. better u give to some data recovery experts. Check on the seagate website for authorised experts.. Shac
Posted on Sep 03, 2007
  • Sarath Chandran
    Sarath Chandran Sep 03, 2007
    Brigadier General:
  • 6,966 Answers
Hi, I have seen a lot of this lately and apparently it is the heat buildup inside the enclosure that kills the drive. You can try running SeaTools for Windows for diagnosis and/or GetDataRight for file recovery. (There are other recovery software available which are just as good). In some cases what I have done is to physically extract the actual hard drive from the enclosure and connect it either IDE or SATA to a working desktop; run diagnostics and file recovery programs. This of course would void any warranty but 50% of the time data was recovered. I had also to install a 3rd HD where I can save the recovered files as well as an extra blower to cool the drives. Again, there is no guarantee with the above method. If the files are really mission critical, you might be better off seeking professional services of data recovery firms. Post back how things are or should you need additional information. Good luck and kind regards.
Posted on Sep 01, 2007
  • 3 more comments
  • Louie  Role
    Louie Role Sep 03, 2007
    Hi again,
    "How would SeaTools or GetDataRight....."
    Based on experience, Seatools 50% of the time will read the presence of an external HD even if Windows does not, it might fail the HD in its generic (short/long) diagnostic but as said 50% of the time the HD was read.
    The file recovery program (My apologies, it should be GetDataBack not Right) is designed specifically for these cases. I have used it to retrieve/recover files (either in FAT32 or NTFS) of HDs even those that Windows says is not formatted or does not have a partition. It will even recover files that you have intentionally deleted as well as temp and Internet Temp files.
    "Since I have a warranty ...."
    Replacing the unit would be to your advantage.
    "The biggest problem ..."; "Will they recover my files?"
    Based on past dealings with the local representative of Seagate, No, they will not try to recover any of your files.
    Maybe you really should try using a file recovery software before asking them for a replacement.
    Are you comfortable cracking it open and removing the actual HD? if yes you may want to try and remove the HD & install inside another desktop PC, that way it is directly connected to the motherboard which would facilitate a lot of the diagnostics and file recovery.
  • Louie  Role
    Am currently working on a couple of these external storage. A Seagate is attached right now. Below is a screenshot of Windows not recognizing the external HD via its USB connection but Seatools is performing a short generic diagnosis on it.
  • Louie  Role
    and below is a screenshot of GetDataBack recovering files that Windows cannot see.
  • Louie  Role
    Louie Role Sep 04, 2007
    Warranty replacement, there you go.
    As long as the external hard drive is attached to its power source, turned on and connected by USB, both programs will try and access it even if Windows does not even recognize it. Please refer to the images posted prior to this response.
    For all its worth, I personally would stick with Seagate (even if I repair more Seagate than Maxtor drives. If I am not mistaken Maxtor is also owned now by Seagate).
  • Louie  Role
    Louie Role Sep 05, 2007
    Re Net Framework version 2.0 should do just fine.
TRANSCEND MP330 ISSUE: i bought this player a year go and was working fine as mp3 and data storage, however i recently noticed my PC/Laptop has not detected the USB drive anymore but i can still listen to...
Do I understand correctly that your computer is still playing music that is only on your USB drive device but it does not recognize the device with a drive letter?
If you had to install a driver then uninstall it and try reinstalling it. If you did not have to install a driver or this doesn't help then shut the computer down. This means turn it off, no sleep, hibernate, or any other sort of shut down mode I mean really shut it off.
Unplug this device turn the computer back on and let it boot up completely.
Shut the computer down again, completely. Turn the computer back on and once it boots up completely try plugging your device back in and see if everything is now recognized. Does it beep when the device is plugged in the same way it did when you first plugged it in when you first got it?
If it still does not find your USB drive and it beeped differently then there's some problem with the computer seeing the device. My next attempt would be to check the USB wires to be sure they are still working, full continuity from one end to the other.
If all this is working then perhaps something may be wrong inside the device.
Nov 01, 2017 | Audio Players & Recorders
XP would not recognize my e250 (new version)
The latest version of the Sansa E250 only has one mode... MTP. USB mode has been removed. My windows XP laptop would see the device and install it fine, but Media Player, Yahoo Music, and any other software would not recognize the MTP device until I installed Windows Media Player 11.
Once installed, even Yahoo Jukebox recognized the device.
I returned 1 & got a new one before I tried this solution. So if you're having a similar issue, don't return it until you've tried the latest version of WMP.
Hope this helps.
on Dec 04, 2007 | SanDisk Sansa e250 MP3 Player
My oxygen 49 3rd generation (m-audio) midi keyboard just stopped working for me. Ive tried changing the usb lead, and I've tried it on a different computer, and it still doesn't work. I have a macbook pro,...
If the keyboard is lighting up, there is a 90% chance the problem is in the software in your MAC.
Hint: Software "breaks" easier than the hardware !!!
Re-install your software as a first step.
Sep 12, 2010 | M-Audio Oxygen 49 USB Midi Controller
Truly HD900 not recognized
You Can Download Free MP3 From Youtube By This Site :
If you didn't found Your Favorite Music In Youtube Try These Sites : or
Feb 15, 2009 | Truly HD900 4 GB MP3 Player
IRiver Music Manger not recognizing iRiver player when connected
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Jan 23, 2009 | iRiver iFP-795 MP3 Player
Usb drive not recognized
try to re-install the drivers for the mp3 player...that might work...or try using other programs to download music rather than windows media player. that is not the best thing to use to get music...try something like limewire, ares or even i-tunes.
Jan 05, 2009 | Coby MP-C7085 MP3 Player
Canon Powershot A80
If nothing else works, try using a usb card reader to get the pictures into the computer's hard drive.
A nice usb card reader is available in all electronics stores such as Best Buy, Walmart, RadioShack, and so on.
Jul 14, 2008 | Canon PowerShot A80 Digital Camera
Reformat the drive then it should be fine.
It would work.
Jul 06, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba A105-S4344 DVD-ROM not working
possible a loose connection, check to ensure you close the drive until a check is heard.check device manager to ensure device is listed and then go to its 'properties' ensure the current devis is could also do a remove device,reboot, and have OS recognize a new device.clean the device with a lens cleaner.
Jun 22, 2008 | Toshiba Satellite A105 Notebook
HD-HC500U2 takes 30 seconds to mount
So what's the problem? It looks like it's working just like it's supposed to.
Nov 13, 2007 | Buffalo Technology DriveStation HD-HC500U2...
Seagate ST3500601XS-RK 500 GB SATA II Hard Drive Logo
509 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
