Question about Bang Olufsen Bang Olufsen BeoCom 1 24 GHz 2Line Cordless Expansion Handset
Beocom 6000...static on calls and flashing light on handset...
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: Beocom 1 handset sends a
Usually the message power off comes when the unit encounters a system error. System error atimes can be corrected by removing the battery for about 5 minutes and replacing it. This solves light system errors. On the other hand if after this process of resetting the error persists then your unit has a problem with the internal processor and therefore will need an expert to take a look at it and if probably replace the processor or the power unit depending on whichever one is wrong with the unit.
Get an expert to take a look at it if the reset does not work and let me know what the result is.
Hope this solution has been helpful?
Posted on Jun 27, 2011
Battery does not chrge in handset
Could be the connections on the bottom of the phone need cleaning. Use a pencil eraser to clean the connections in the cradle and on the bottom of the phone.
May 21, 2015 | Lands Phones
How do I add new phone to Pyramid wall charger for 6000 B&O phone which does not have a light
Might be best to read this article which explains the differences and similarities.
PSTN Bases Phone Compatibility Explained
The appropriate user guide to suit your system will be available on this site. Choose the correct model.
http://www.bang-olufsen.com/en/customer-service/product-support/accessories/phones/beocom-6000
Sep 13, 2014 | Bang Olufsen Lands Phones
Mitel Superset 420 corded phone has static
Static on the handset of a MITEL phone is indicative of either a defective handset cord **OR** the user has one of those cord detangler devices attached to the cord. If it's a cord detangler, remove it, smash it with a hammer and throw it away. Advise the end-user to please not use these as they all become staticky after several weeks use. If the user has problems with their handset cord constantly becoming tangled, THAT PROBLEM is indicative of neck or ear fatigue from frequent LONG CALLS and the user keeps moving the handset from one ear to another (changing hands). THE FIX FOR THIS is to give the user either a corded or cordless headset (or check SMDR records for excessive personal calls)
Feb 12, 2014 | Mitel Superset 420 Corded Phone
Handset shows line busy
its not syncing to your phone the right way.
Aug 15, 2013 | HQRP Phone Battery fits BANG & OLUFSEN...
Beocom 6000 line busy
BeoCom 6000 is a cordless system phone with advanced features and elegant design
May 19, 2012 | Office Equipment & Supplies
My Beocom 6000 table base unit no longer charges
If your base has a charge indicator on it and it indicates that the handset is charging when the handset is in the cradle, I would say you need a new battery. RadioShack sells a replacement battery for $22.00 at the following link
http://www.radioshack.com/product/index.jsp?productId=2815547&CAWELAID=107599274
If the charge indicator doesn't come on it is unlikely that it is the battery. You may be able to get the phone repaired by the manufacturer but it may be better and more practical to get a new phone.
Jan 07, 2010 | Lands Phones
Beocom 2400 earpiece soundcable problem
Hi I also had a problem with the wires breaking on the handset of my Beocom 2400 , and I could not find out anything on the Internet .
But I managed to fix it without to much difficulty !
So I thought I try and help people in the same situation out !
Anyway to split the handset you will need a plastic card , like a credit card , store card etc) as in picture . DO NOT USE anything made of metal !!!
You will need to start at the bottom of the handset where the microphone is ,on the right hand side looking at the front of the handset .Insert the card,only a little way about 10 mm, then draw the up where the seam is , once it has started to separate you will find it will become easier as you work you way round .
Once you have separated the two halves you then need to peal the outer casing off the cable find the break cut it out and solder the wires back together ,I used heat shrink to cover the bare wires as in picture .
When you have done this it is just a case of sticking the two halves back together , Don't use instant glue!! use a glue which will give you time to position the two parts as it is not that easy , then clamp the two parts together with cable ties , as in picture .
Clean off any glue ,leave for glue to set remove cable ties , job done .
I hope this has been of help to someone!
Regards Stuart . dorsetpicture.co.uk .
http://farm3.static.flickr.com/2460/3814339247_8767c2aa31_s.jpg
http://farm3.static.flickr.com/2444/3814339347_83180a9499_s.jpg
http://farm3.static.flickr.com/2513/3814339477_9577cf01d2_s.jpg
http://farm3.static.flickr.com/2447/3814339721_72d7e68176_s.jpg
http://farm4.static.flickr.com/3556/3814339799_b30d7d805a_s.jpg
http://farm3.static.flickr.com/2461/3815149182_c31a69fc0c_s.jpg
I take no responsibility if you bugger it up ....
Jun 16, 2009 | Bang and Olufsen Beosound 4000 Shelf...
Plantronics cs50 head set with lifter has STATIC
Try a system reset:
1.  Lift the headset off of the charging cradle, but make sure the headset is turned off.  It will be off if the green light on the front of the base is not lit.  If it's not, push the call answer button once to turn it off.
2.  Push the call answer button and the mute button at the same time and hold them down.  The mute button is the black little wheel at the top of the headset.  Use the tip of your finger to push it straight down and hold it while holding the call answer button.  A green light on the headset will flash for 2 series of flashes.  Wait until the end of the second series then let go of both buttons.
3.  Put the headset back on the charging cradle and wait 30 seconds.  Lift it back up and try to use it.  If this doesn't work, repeat one more time and then disconnect the power from the base and plug it back in.
Apr 24, 2009 | Plantronics CS50 Wireless Headset
Problem with B&O beocom 6000 ''extension'' no contact with base
I think you just need to re-register the phone to the base. Press the button on the base station (between the 2 charger pins) then go to the handset setup menu, scroll to register handset.
Feb 25, 2009 | Lands Phones
Bang  Olufsen Bang Olufsen BeoCom 1 24 GHz 2Line Cordless Expansion Handset Logo
Top Bang Olufsen Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Bang Olufsen Lands Phone Expert? Answer questions, earn points and help others
