I Bought a ProLite x2377hds monitor with my
I Bought a ProLite x2377hds monitor with my computer a couple of days ago. I plugged all the cables in the right places because they are coloured coordinated but still im not getting any signal when I turn them both on. I've tried plugging them out then back in, changing the channels to see if one of them will get a signal but their all the same also tried using a hdmi to see that helps nothing so if anyone who has this monitor or who can just help I would be very grateful thank you.
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
SOURCE: colour changing
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
Posted on Jun 05, 2008
yooperbud
  • 8637 Answers
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
  • 4234 Answers
SOURCE: CHECK SIGNAL CABLE
Typically this happens when the resolution of the display is out of range of the monitor. Normally this is when the resolution is too high. Have you changed the resolution settings? Also, not to be crass, but if there a video card in the system, be sure that you are connected to the correct VGA connector. With an extra card in the system, the onboard VGA connector is not used.
Keep us posted,
Dan
Posted on Jan 23, 2009
  • 40 Answers
SOURCE: No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Posted on Jul 31, 2009
Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
We have a hp m8000 pavillion with a 17 " monitor purshased 2007. we bought a hannspree 22" lcd widescreen a couple of days ago. when we plug it in its say no signal. however when we plug it into our lap...
that happened to me. I felt stupid when I discovered what i did wrong. I attached the monitor cable to the connector at the top of the back of the computer(where it is supposed to attach, right?) - but, there was another connector for the monitor at the bottom of the computer which had been a special "card" add on. the monitor jack at the top did come with a plastic covering which meant not to use it. i thought the covering was just a protector, i didn't know. live and learn i guess.
Dec 26, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Colour changing
Feb 23, 2008 | iiyama ProLite E434S 17" LCD Monitor
Screen keeps changing to different colours when i switch pc on
Have you tried checking that it's plugged in firmly to your CPU?
You might need to screw the caps on the side to ensure that's the case.
Iiyama prolite e483s. no sound
Get a cable two male ends. Look for the female end on your screen. Put one male end into the port on on your screen and the other end into the port "AUDIO ONE" on your computer.
Try this it should work. The Multi-PIN cable is only for VIDEO, you need another cable for AUDIO.
Jan 27, 2008 | iiyama ProLite E481S-B 19" LCD Monitor
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
