Question about Raymond Weil Watches
Raymond Weil Jasmine losing date everytime I go to wear my watch which is really on special occasions i find that I have to wind the watch to get the date right would this be a simple battery issue?
  • Raymond Weil Master
  • 18,424 Answers
The problem is some month's av 28 days and some month's av 31days, but on your watch the wheel that as the numbers on has 31 days so if there's a month with 28 days you'll need to change it manualy hope this helps you,,
Posted on Aug 01, 2013
SOURCE: My watch Raymond Weil Geneve,
It may be not a solution. The thing had done as below:
I replaced at home by myself, but it didn't work. I brought it to a watch repair store at Paramus. The technician replaced its battery but it didn't work. He said that the watch was out of order and need to repair. It will take one week. I left it to him and I am waiting for the result.
Posted on Aug 24, 2008
SOURCE: Operating Raymond Weil W1
It's the reset button.
Posted on May 23, 2009
  • 26 Answers
SOURCE: Raymond Weil quartz watch crystal date window
yes they do but it is pricy
Posted on Jul 13, 2009
  • 2501 Answers
SOURCE: my raymond weil watch has stopped i have changed
I suggest that you go to your nearest dealer.
The address can be found on the web site "www.raymond-weil.com/".
Click on "store locator".
Posted on Feb 16, 2010
  • 93 Answers
SOURCE: My Raymond Weil ladies watch (Style 5360TT/WI) was...
Hi Connie,
If the watch has had moisture in it the hands may be damaged and need replacing. But most likely this is not the case and it is one of the things manufacturers try to force customers to pay for when they don't need to.
An independent watchmaker can service your watch most times for less than the manufacturer. Part of this savings is from not forcing you to buy parts you really don't need. The other savings is from much lower overhead so the watchmaker doesn't have to charge as much to make ends meet.
You might get your watch back and send it to a professional watchmaker and get an estimate from them. It will probably be less than you were quoted.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
Posted on May 24, 2010
Raymond Weil watch Serial #K004743 18K gold plated, 3ATM waterproof What type of mechanism this watch has.Quartz or self winding? What's it's worth?
$450 to $1,300 new. They go by names rather that model numbers. That looks like a serial number, but you could ask direct. They are all self winding automatics except for some fakes. You can test this yourself. Hold the watch in one hand by the strap and tap it sharply onto your other hand twice in quick succession. Put the watch quickly to you ear and see if you can hear the counterweight spinning, and then slow down and stop.
Raymond Weil watch Serial K004743 Google Search
https://www.raymond-weil.com/en/faq-and-contact
Jan 30, 2018 | Raymond Weil Watches
I just got the watch as a gift on x-mas it stopped working yesretday while I was wearing it mens giovanni self winding I pushed the second hand button A and nothing I didn't drop it or get it wet or...
Having read the limited instructions for this watch, it does not seem as though there are many options available!
If you haven't already done so, try pressing A again.
If nothing happens, press B
It could be that the watch has simply stopped because it needs re-winding (it depends on how long it had been running when you got it.
To wind the watch swing it gently from side to side for a few minutes. ( some makers say swing it 200-300 times!).
If you still have no joy, then contact the makers help line; go to http://www.raymond-weil.com/EN/Swiss-Watch-Company/After-Sale-Service.html to find your nearest service center.
Jan 03, 2011 | Raymond Weil Don Giovanni Chronograph...
How do you get the back off for new batt
Replacing a Raymond Weil watch battery should be performed by an authorized Raymond Weil dealer. Replacing the battery on contemporary Raymond Weils takes some skill because the case is pressurized on some models or contains a rubber gasket to keep it water-tight. If you determine your Raymond Weil watch has a pressurized case back, don't attempt a battery replacement. Take it to an authorized dealer. The warranty on a recently purchased Raymond Weil watch will be voided if you perform a battery replacement yourself. Replacing the battery yourself on older Raymond Weils without a warranty is an acceptable risk.
Aug 23, 2010 | Raymond Weil Watches
Raymond Weil 8600 Brand new how to get second hand moving
To start the watch when it has not been worn for a day you must manually wind it by turning the crown clockwise about 40 turns. After that it will stay powered if you wear it every day and are reasonably active. If it stops just manually wind it to get it going again.
Apr 24, 2010 | Watches
Watch stopped running when not worn for days. turned crown 20 times per Raymond Weil manual, did not work.
Make sure you are turning the crown clockwise and stop winding when you feel the tension increase. Also, try wearing it for a day even if it is not runninr; the motion may be enough to get it going if it is an automatic.
There may be something more wrong with your watch.
If the RW is less than 2 years old you should be covered, they have one of the best warranties in the business.
If it needs repair and is older than 2 years, I would still send it to the RW repair center in NY to see what they can do.
Oct 17, 2009 | Raymond Weil Parsifal W1 watch
Fixed my Raymond Weil W1
You should try to contact :
Magnum Indústria da Amazônia S/A
Alameda Santos, 1940 / 11º andar
São Paulo
Brazil
email: roberto@magnumsa.com.br
tel: 00 55 11 3149 2590
fax: 00 55 11 3285 4299
i found this information on the RAYMOND WEIL Luxury Watches Official Website, on the RAYMOND WEIL After-Sale page.
Hope this helps !
:) david
Jun 03, 2009 | Raymond Weil Parsifal W1 watch
Watches Logo
Top Raymond Weil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Raymond Weil Watch Expert? Answer questions, earn points and help others
