Question about Health & Beauty
How to put this lamp straight
I screw up down , can't figure it out?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Use a level
Posted on Aug 20, 2013
Lionel train desk lamp not working consistantly.
There are 6 rubber foot pads that under each one is a screw. I had the same problem and we found out that there were screws under the rubber foot pads. Once we were done we glued the rubber foot pads back on the lionel lamp. (Lionel Train Desk Lamp)
Apr 21, 2013 | Toys
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
How do I change the lamp.
1. Turn TV power off and allow the lamp to cool at least one hour before proceeding.
2. After the lamp has cooled, remove the plastic air exhaust grille/cover by removing two screws with a #2 (large) Phillips screwdriver. See figure 1.
3. With a large flat-blade screwdriver, loosen the three shiny screws securing the lamp cartridge until they disengage from the mating threads. These are captive screws and cannot be separated from the lamp cartridge.
4. Fully open up the bag supplied with the replacement lamp and set the opened bag aside.
5. Grasp the wire handle of the lamp cartridge and pull the old cartridge straight out towards you. See figures 2 and 3. Note the orientation of the cartridge.
CAUTION: Do not tilt or rotate the cartridge, as small glass fragments may fall out.
6. Without tilting or putting down the lamp cartridge, insert it into the opened bag. Close the bag while being careful that no glass particles fall out.
7. Do not touch the glass parts of the new lamp cartridge. Insert the new cartridge into the TV in the same orientation as the old cartridge. Push on the cartridge housing until it is fully seated.
8. With either your fingers or the screwdriver, gently tighten the three screws. If using a screwdriver, use only two fingers for final tightening. AVOID OVERTIGHTENING!
9. Replace the plastic grille/cover and retaining screws.
10. WASH YOUR HANDS THOROUGHLY, AS THIS LAMP CONTAINS MERCURY.
11. Contact your local authorities or the Electronic Industries Alliance at www.eiae.com for lamp-disposal or recycling instructions. Do not dispose of the old lamp with common trash.
12. Reset the Lamp Reminder from the TV Setup menu as follows:
a. Press TV MENU to open the Setup menu.
b. Move the highlight to Lamp Reminder.
c. Press ENTER twice.
Sep 15, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Sony model KDF-50WE665. Made a pop and the picture went out. I think it's been slow to come on now for a couple of weeks, so it's probably the bulb. Can you tell me: 1) Where can I buy...
The lamp you need is Sony XL-2100U ($78 at Amazon) or XL-2100 ($84 at Amazon).
Turn off the TV and wait a few minutes before you unplug it (let the cooling fan run). Then wait at least another 30 minutes before replacing the lamp. There are two screws on the rear panel (left and right sides near the top left of center of the small panels on the on the ends). Loosen the screws and then pull off the front panel (below the screen). The front panel has to be pulled off in stages - start at the right side and pull forward and down, then the left - pull forward and down and then the middle - pull forward and up. Loosen the screw on the lamp cover with a coin and remove the cover. Loosen the two screws that hold the lamp (use an allan wrench) and remove the lamp by pulling it straight out. Slide in your new lamp (handle with care - use a glove to avoid any oil from your skin getting on the bulb). Tighten the two screws. Then replace the lamp cover and tighten the screw. (Make sure that the screw goes into the unit straight - otherwise the safety lock may keep the TV off.) Reattach the front cover and then tighten the back panel screws. Put the old lamp in a box after it has cooled completely for disposal.
Pictures are available in the User manual here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF50WE655 . The appropriate section starts at page 16.
I hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Replace front blinker on 2003 chevy cavalier
1. You'll need your ratchet set, a flat head screwdriver, maybe needle nose plyers, and a replacement bulb.
2. You'll need to loosen (but not remove) the black, radiator cover in order to get access to the headlamp. There are 6 black, plastic, circle shaped plugs with a small circle inside the large circle. Use the flat edge of the screwdriver to pry that smaller circle upwards. Once it's able to be grabbed, pull it straight up with your fingers and it will pop out nicely. Do this with all six plugs.
3. Next, remove the two bolts that hold the lamp in place. There are actually 4 bolts in the same general area, but you only need to remove the two that hold the lamp in place.
4. Carefully tug, twist and turn the lamp so that you pull it out of it's socket by about 8 inches. Let it sit on the bumper. This should give you enough room to access the correct bulb from the back of the lamp.
5. Turn the bulb plug counter clockwise and it will eventually pop out of the lamp.
6. This is where I screwed up a bit, I pulled the bulb out, but it broke and left the plastic part still in the plug. So there is probably a release mechanism that I didn't see. I used the needle nose plyers to carefully remove the plastic part of the bulb from the plug. I think I broke a bracket on the plug, so be careful.
7. Push the new bulb straight into the plug. No turning required. Just straight in with a click.
8. Insert the plug back into the lamp, turn it clockwise to lock it into place.
9. Shimmy and twist the lamp back into position and screw it back into place.
10. Use your fingers to put the 6 black circle shaped plugs back into place. Just position them over the hole, make sure the small circle is pulled all the way out, push the big circle through the hole, then push the small cicle down to lock it into place. Sounds difficult, but once you see it done a single time, you'll be an expert.
If the bulb didn't break, the entire job would have taken me 15 minutes at most. Good luck!
Here is a great write up from this link:
http://www.topix.com/forum/autos/chevrolet-cavalier/TBM1SIDF08KBT7IIC
It explains it in great detail that should help you perfectly.
thank you and enjoy,
Lee
May 10, 2011 | Chevrolet Cavalier Cars & Trucks
I don't have an owner's manual for my wd 60735, but I need to change the bulb. whatt are the steps I should follow?
Removing the Old Lamp Cartridge
Turn off TV power a 1. nd allow the lamp to cool for at
2. After the lamp has cooled, remove the cover of the
lamp compartment, located on the back of the TV.
Refer to figures 1 and 2. Use a #2 (large) Phillips
screwdriver to loosen the screw securing the cover.
Keep the screw and cover for re-installation
3. With a large Phillips screwdriver, loosen the two
lamp cartridge.
4. Fully open the bag supplied with the replacement
5. Gently grasp the handle of the lamp cartridge and
pull the old cartridge straight out. See figure 3.
being careful not to let any glass particles fall out.
Installing the New Lamp Cartridge
1.
2. With either your fingers or the screwdriver, gently
tighten the two shiny screws. If using a screwdriver,
3. Replace the plastic cover and retaining screws.
4. WASH YOUR HANDS THOROUGHLY, AS THIS
Nov 11, 2009 | Mitsubishi WD-60735 Projection Television
License plate bulb 99 alero
remove the 2 license lamp screws from outside,above the lic.plate then from insidethe trunk pull up the lic.lamp housing and replace the bulb.it should pull straight out
Apr 21, 2009 | Oldsmobile Alero Cars & Trucks
Changing lamp
six red flases ruile is the thermo fuse
Nov 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Health & Beauty Logo
415 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
