Question about Exercise & Fitness
8925 HARD DRIVE SYSTEM assembly instructions required
How do I use the password protection?
Your questions isn't too specific but I hope this helps
There are several ways to incorporate password protection. You can set the computer to require a boot up password in the computer BIOS. You have to enter the computer BIOS as soon as you turn it on; with a Dell press [F2], with HP press [Esc] and select system configuration. In the BIOS you can set the BIOS Administrator password - controls the ability to change BIOS settings, the computer boot password - when enabled it requires the user to enter the bootup password before the computer will boot, and set the hard drive access password - controls the users ability to access a hard drive.
The next level of password protection is at the operating system level - account access levels, privilege levels, and passwords. Dependent of operating system you can also set hard drive encryption
Oct 28, 2014 | Maxell MAXDATA 503802 - FLIX8G HIGH-SPEED...
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
Would copy-pasting the entire contents on one hard drive to another hard drive work? (Including OS)
Dear Friends.
Yes..its possible you can connect two hard drive and transfer you data one drive two another drive, please follow mention below instruction and solve you problem.
  1. As per your question you have two USB hard drive, then what you have to do first connect you USB Hard drive in laptop which hard drive you installed the Operating System.(Ubantu 32bit)
  2. Start you laptop and when the operating system windows or home page will after that you can connect your second Hard drive.
  3. First time it will install the require USB drive, wait few second, after finish the driver installation go to the my computer and find you second hard drive.
  4. Now Easily you can transfer you data form one hard drive to other hard drive.
Thanks Your For Visit and post the Question....on Fixya.
if any kind of help you require, let me know
Prashant
Sep 05, 2012 | Computers & Internet
How to open laptop
Hi Dear...........
If you want open any electronice think you need to complete tool box with first ad. If you have a complete tool then follow the mention instruction and open the laptop, if you don;t know anything about laptop then don;t try to open it.
  1. Reverse the laptop as shown in the figure. And remove the battery. Open the the screws from back side for the Wi-Fi card cover, the modem card cover, the memory card cover, the hard disk cover.
  2. Reverse the laptop as shown in the figure. And remove the battery. Open the the screws from back side for the Wi-Fi card cover, the modem card cover, the memory card cover, the hard disk cover.
  3. Take out the Wi-Fi card cover, the memory card cover, the modem card cover, the hard drive cover. Place them at safe place.
  4. You may require to Open the DVD drive with a paper clip.
    Carefully take out the DVD drive from the computer. In most of the computer one screw from the back site of the laptop fix the DVD Drive. So you have to remove all the screw from the bottom of the laptop.
  5. Insert a thin object under the securing strip(keyboard bezel) and lift it up. Be careful, it may be very tight(there are no screw at keyboard bezel in most of the cases)
  6. Take out the securing strip(keyboard bezel).
  7. Now you can see two screws securing the keyboard and these screws are easily visible remove those screws.
  8. Now careful keyboard is connected with flate ribbon cable to the system board. Disconnect the keyboard cable from the main board and remove the keyboard.
  9. Now you can fine one cable(most probably black colors) from LCD and it is connected to system board. Disconnect the LCD cable from the system board.
    Remove the screw connecting the LCD cable to the base.
    Disconnect the flat LED board cable from the system board.
  10. Carefully lift the display/LCD assembly off the base.
    The display/top cover assembly - LCD assembly and top cover assembly connected by hinges.
  11. Remove the screw securing the HardDisk holder.
    Remove the Hard disk holder.
    Disconnect the left and right speaker cables from the system board.
  12. Now remove five screws securing the heatsink assembly for CPU. And disconnect the fan cable from the main board.
  13. Carefully take out the heat sink off the CPU. And be sure to put heat sink thermal jel /glue when reconnecting the heat sink.
  14. Remove two screws normally at the corner side connecting the system board to the base
  15. Now lift of the system board starting from the left side, be careful with the PC card connector.
  16. Remove the system board off the base.
  17. Modem card is still connected to the system board with screws securing the modem card. If you want you can remove modem card.
  18. Remove the screw securing the optical drive holder.The screw is hidden under the black tape.
  19. Remove the optical drive holder.
  20. Remove four screws securing the card bus connector (PC card connector).
  21. Turn the system board right side up.
  22. Carefully remove the cardbus connector.Unlock the CPU and lift it off the system board.
  23. Turn the system board upside down.Remove two screws securing the video chip fan.
  24. Remove the fan cable on the system board.
    Remove the video chip fan
  25. Hay great techie guy you have done it.
Video :
Part 1
Part 2
Jan 09, 2012 | Computers & Internet
1)How to find and remove the hard drive on the IBM ThinkPad T22 2647. 2)The comp appears to start but screen is blank
hi
to remove the hard disk, remove screws from small hard disk drive door (loacted on back of notebook), disconnect the hard disk by removing two screws (if applicable) pull tab to remove disk.
OR -----
if you do eventually get access to your operating system , when computer runs normally ---
run this test ,, read carefully and follow instructions - go to this link and download the program first
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70578
then follow instructions below.
Windows XP
  1. Click Start, select Search, then click All files and folders.
  2. Type hddquicktest_setup_60549818x86.exe in the search field, then click Search. This will locate the file you just downloaded.
  3. Double-click the hddquicktest_setup_60549818x86.exe icon.
  4. PC-Doctor for Windows will be installed on your system.
How to Run Lenovo Hard Drive Quick Test
Summary
Lenovo Hard Drive Quick Test is a diagnostic tool that tests the hard drives in Lenovo ThinkPad, ThinkCentre, and Lenovo 3000 computers running Windows XP or Vista released after January 2004. If you are experiencing issues with your Lenovo product, you may run this test to determine if your issues are hard drive related.
Running Lenovo Hard Drive Quick Test
To run Lenovo Hard Drive Quick Test from Windows, follow these steps:
1. Download the test to your computer.
2. Run the application install and choose the defaults. Once installed, the application will be placed under a "Lenovo Services" choice on your Start Menu.
3. If the application detects that the Lenovo System Toolbox is already installed, it will ask whether you want to continue the installation. This is because the new hard drive test is installed by default as part of the Lenovo System Toolbox.
4. Choose a drive if you have more than one drive.
5. Start the Test
Testing in process:
1. The test may take 4 to 6 minutes depending on the size and speed of the drive.
2. When the diagnostics are complete, a message will be displayed indicating that test "Passed", "Failed", or "further testing is required to verify the drive's proper operation". If further testing is required, start running the extended test. The test may take more than an hour depending on the size and speed of the drive.
3. When the diagnostics are complete the extended test, a message will be displayed indicating that the test Passed" or Failed".
4. If the test failed, contact Lenovo Support Center
Note: Lenovo Hard Drive Quick Test is included in http://www.lenovo.com/systemtoolbox
Lenovo System Toolbox is a full application of computer diagnostics utilities.
hope this helps
Nov 15, 2010 | IBM ThinkPad T22 2647 Notebook
I require instruction on the use of my portable hard drive.
its very easy. just connect to your computer usb port. If your drive requires power put the power adapter. Before connect to frontpanel USB of your system. Once check your front panel usb is working or not. Check with some other memory stick or mouse etc.. Because if your front panel usb connect reverse there is chance to lose your hard drive..
Jun 24, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Tilt 8925 sound problem
it sond like sound configuration save all info an contacts and hard reset push and hold the 2 soft key the ones have a -- simbol and with the stilus push the reset boton for 3 second who is beside the usb conector and falow the instructions good lock
Nov 18, 2008 | AT&T 8925 Tilt Smartphone
Forgot my admin password for my notebook
No worries about taking the Backup of data before reinstalling the Operating System in your Notebook.
I recommend you to remove the Hard Drive of the Notebook and connect it to the USB Port of any other computer using some cables that will be available in most of the computer part stores and copy the required files in the computer to which the hard drive is connected.
You can find the required instructions to remove the Hard Drive of your Notebook from the Manual which is available in the link below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructions to remove the Hard Drive of your Notebook starting from page number 100 of 233 in the Manual.
Find some cables which can be used to connect the Hard Drive of the Notebook to another computer by clicking HERE
Once the required data is saved, reinsert the Hard Drive back in the Notebook and perform a full recovery by following the instructions listed below using the Recovery Partition  with Vista :
Restart or Start the Notebook and start tapping the F11 key immideatly after the Notebook restarts.
This will take you to the Recovery Manager window.
In this, click on the Advanced button.
In this, you will get the following options :
a) Computer Checkup
b) Microsoft system restore
c) File backup wizard
d) System recovery
Click on System Recovery.
In the window that opens, you will get the options...
Do you want to back up your files first (reccomended)
or
Recover without Backing up.
You can take a backup of the data in the Hard Drive if you have any External storage devices like External Hard Drives connected to the Notebook.
Select the required option to proceed with the Recovery.
The Operating system in the Notebook will be reinstalled along with all the Preinstaled Applications and Drivers to factory default settings.
Hope this helps....
Nov 01, 2008 | HP Pavilion dv6000z Notebook
Exercise & Fitness Logo
59 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
