Samsung wa13v5 drain pipe - Washing Machines
Where can i find a wiring diagram for samsung washing machine wa13v5
There is one put inside the back panel on all major appliances .
Dec 21, 2016 | Samsung Washing Machines
Fitting a motherboard to my Samsung WA13V5.There is a terminal under the digital display that does not have a visible matching plug. The motherboard part number is DC92-00278L.
The controller may be applicable to a number of models, depending upon how it is configured. Your washing machine may not use that terminal.
Jun 20, 2016 | Samsung Washing Machines
Samsung wa13v5
try lifting the drain pipe to at least 27 in or 70cm the pipe should not be on the ground
Feb 12, 2014 | Washing Machines
Samsung wa13v5
The seals in the bottom of the drum where it connects to the gear box is going bad. Changing them out is something that you can do but it is not easy. You pull off the top cap on the agitator and then take off the nut and lift the agitator out, then you can see the seals.
Jan 19, 2014 | Washing Machines
Samsung wa13v5
Your problem didn't get posted.
Nov 27, 2013 | Samsung Washing Machines
Samsung WA13V5 Fully Automatic Washing Machine. Code error:E4. We bought this machine on 15 August 2012 with Gaurantee of Two Years and a extended Warrantee of 2 years at Game store ILLanga Mall Nelspruit....
when you say water goes out at the same time as going in? have you put the bent in the back of the drain pipe or is the pump pumping it back out ?
Jul 01, 2017 | Washing Machines
Hi, I have the WA13V5 toploader. The machine is 7 months old. Yesterday the machine still worked 100%. This morning the water does not want to flow into the machine. I have checked the water flow and the...
Hi
There is a filter located in the pipe between the connector to the water outlet and the machine, This sometimes gets clogged. If this dos not solve the issue then time to call a tech. Anyway your machine is just 7 months old and it should still be in the warranty period and the service should be free.
Regards.
PLZ. don't forget to rate my suggestion.
Jul 19, 2011 | Samsung Washing Machines
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
