Question about HP COLOR LASERJET CM3530FS UP TO 31/30PPM DESKTOP COLOR MFP; BASE
Lines or Streaks When printing -- HP LaserJet MFP 3530
manojro
  • 495 Answers
SOURCE: HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Posted on Feb 12, 2009
SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
Posted on Apr 05, 2009
SOURCE: My LaserJet printer prints lines or streaks on every page
Can't read the entire heading for your post, but it sounds like a defective toner cartridge. Replace it.
Posted on Apr 26, 2009
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: Our HP Color LaserJet CM 3530 will not scan or print
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodTypeId=18972&prodSeriesId=3709253
This is HP's troubleshooting site for your printer.If you can't find what you need there's a "contact HP"button where you can talk with a tech.Good Luck!
Posted on Dec 31, 2009
Can't get a clean print job
clean the printer back side of the sensor & check.
Dec 18, 2013 | HP LaserJet M3027x MFP Printer
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
HP Laserjet M2727nf Mfp Printer scan to e-mail first page correct but other pages come out with lines
First print a test page out from a computer. If this has lines then its either a dirty drum in the toner cartridge or a bad fuser. IF the test print is fine then you just need to clean the glass over the scanner.
Jun 11, 2012 | HP Laserjet M2727nf Multifunction Printer
Hi there, my hp laserjet M1120n MFP is printing with thick black lines? Please assist.
Hello
Unfortunately Thick black lines usually indicate a Fuser-Drum issue. These parts can become worn over extended use and should be replaced. You can try pulling the toner and drum unit out and re-installing them, but if the problem continues then a replacement drum is advised.
Regards GM
Apr 27, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
HP LaserJet 1320 Printer
check your fuser assembly
Mar 09, 2010 | HP LaserJet 1320 Printer
It is printing bright blue streaks all over the
Forget the answer above, this printer is a laser jet and dipping anything in water will certainly stop it working.
Oct 03, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
HP Printers: 2600 and 3100N are printing streaks of lines.
2 things;
1. Try cleaning the print head assembly - including the plastic band that runs from 1 side through print head to the other side.
2. Check the driver for printer, reinstall if above does not work.
Jul 09, 2009 | HP Color LaserJet 2600n Printer
Apr 25, 2009 | HP LaserJet 1320 Printer
HP COLOR LASERJET CM3530FS UP TO 31/30PPM DESKTOP COLOR MFP; BASE Logo
Seeker5211
Seeker5211
