Question about Bosch Cooktops
I have the Bosch cooktop Model No. NGT-915 DAU, P990M3X5DA3 I wanted to replace the nipple of the burners and burner caps. I could not find it in Abu Dhabi, UAE, from where I bought the unit. Where else I can find?
catriver
  • 878 Answers
SOURCE: Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Posted on Feb 26, 2007
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
  • 135 Answers
SOURCE: electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Posted on Apr 07, 2008
SOURCE: Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Posted on Aug 18, 2008
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
Bosch Cooktop Model # NGM8654UC 5 Burner. The middle burner ignitor is getting power but not sparking
Change the igniter switch. You can buy from mfr and install yourself.
Oct 06, 2013 | Bosch Cooktops
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
I have a bosch cooktop 5 burner and one burner lites its very dim and then goes out
Is this cooktop new? Was it converted to propane or do you use natural gas? If it was converted, I was just thinking they put in the wrong size orifice. If it has been working fine and is just now giving you problems, then check the burner holes and see if they are partially plugged from food spills.
May 18, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Jan 18, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Bosch ngt cooktop
hi there,
can you elaborate please and also provide the model # off your cooktop please?
Sep 27, 2008 | Cooktops
Burner cap
The cook top should be bolted to the counter. Look under and look for brackets that attach the bottom of the cooktop to the sides of the counter. and also the model number should be somewere underneath. If you can get me the Model number I can get you the maintenance manual in PDF format.
Eddie Rentas
Tupper Lake NY
Jul 24, 2008 | GE 30 in. JGP336 Gas Cooktop
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Clicking
In addition to polishing up the end of the igniter as mentioned above, remove the burner cap cover and and the round burner cap. As noted above, electrical contact or grounding is an important element in the spark igniter function. Any poor contact surface can cause the igniters to continue to spark after a burner lites. If everything seems in order, polish the underside of the aluminum burner cap and the top side of the aluminum burner base (where they come in contact with each other). This is part of the grounding circuit for the igniters. I used an "SOS" pad. In our case, these parts had tarnished with age. My wife was very happy when I fixed this one.
Dec 09, 2006 | Dacor Preference SGM365SS Gas Cooktop
Cooktops Logo
Top Bosch Cooktops Experts
paulcarew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
