I have a Thomas gravel screen. The light for overheating is on. How do I check this?
Hi there I have a jvc tv 'LT-42X788' when I power on the cbc sign comes on I here a click and screen shuts of there's a blue light that came on when I power on it stays on any help thanks
@Thomas Scissons
"JVC LT-42X788 display fault..."
Hi Thomas.
Please pick one:
Power supply board (possibly a blown capacitor):
A TV-tech can repair at reasonable cost, less than a new set.
The main board itself has a control / display section fault:
The screen / panel is shot:
Beyond economical repair - renew set.
Hope this helps.
Clive.
Oct 16, 2017 | JVC Televison & Video
Toyota Caldina 98. In 4-5 different incidents, the A/T oil temp and battery lights went on while driving on gravel.The regulators/alternators failed.
How to read Toyota warning lights. - YouTube
? 2:46
https://www.youtube.com/watch?v=OAcBOTmIgXo
Oct 21, 2012 - Uploaded by NinjightNationCorp
suppose your brake lights aren't blown and that indicator is still lit? ... due to the constant overheating since I ...Missing: grave
Basic Knowledge About Warning Light on the Dashboard ...
www.picknbuy24.com/column_35.html
TOYOTA (1230) ... You definitely don't want to be driving with the brake light on. ... The same goes for the oil light; this light means there is no oil pressure, or that the ... You might also see a battery charge light come on at some point. ... Me Up When I'm Super Sleepy, Vol.237 Simple Tips To Save Gas Without Driving Less ...
Dec 25, 2015 | Toyota Cars & Trucks
Why has my aquarium gravel made the pH level in my tank rise?
It is most likely that the gravel you are using contains calcium and magnesium. This will ultimately cause the pH level in your tank to rise. You should use an inert gravel such as Swell Harlequin Gravel.
http://www.swelluk.com/aquarium/substrate-1695/gravel-1829/swell-harlequin-gravel-blue-376469.html
Aug 28, 2012 | Aquaculture Fish
How do I clean the gravel in my aquarium?
You have a few different options for cleaning the gravel inyour aquarium:1. 1. Remove the gravel from the aquarium and washit thoroughly in a strainer, under warm tap water. Depending on the number of fish you have,this should generally be done once every other week. Do not wash the gravel with any chemical orsubstance as this could be damaging to the fish!2. 2. Use a store bought orhomemade gravel/substrate vacuum. Thisallows you to clean the gravel without having to remove it from the tank.3. 3. Use only a thin layer of gravel on the bottomof your tank and exchange with new gravel each time it needs to be replaced.
May 13, 2012 | Fish
Water pump failed. Car overheated. Engine lost power. Car smoke out from back of engine and from rear of car. I replaced water pump. Car still smokes when I drive it. Still has no power.
Notorious for intake leaks, the composite plastic intakes crack and leak coolant-as to the lack of power, you mght have overheated it and done some damage to the engine. There was a recall (information below) for the 4.6 for the intake-the overheating and lack of power means you should at least have compression checked and go from there-you may have bad head gaskets or worse. Do a compression test before you do anything else.
Ford Motor Company will extend the recall (01M02) on 4.6L V8 equipped vehicles with plastic intake manifolds. Some of the composite intake manifolds used on 4.6L SOHC engines may develop fatigue cracks at the coolant crossover duct. This condition could result in engine coolant leakage which, if not serviced, may cause engine overheating. Complete loss of coolant may result in engine damage or engine failure.
The updated recall now includes:
• Certain 1996 through 2001 Model Year Crown Victoria Police Interceptor
• Certain 1998 through 2001 Model Year Crown Victoria with Taxi
• Certain 1998 through 2001 Lincoln Town Car Limousine and Livery Prep Package
• Certain 1996-2001 Crown Victoria Taxis, Police cars and Lincoln Town Car Limousine and Livery cars.
• Certain 1996 through 1997 Crown Victoria Police Interceptor Vehicles with 4.6L SOHC engines built at the St. Thomas Assembly Plant from the beginning of production for the 1996 Model Year through January 28, 1997.
• Certain 1998 through 2001 Crown Victoria Police Interceptor Vehicles with 4.6L SOHC engines built at the St. Thomas Assembly Plant from November 22, 1997 through December 15, 2000.
• Certain 1998 through 2001 Crown Victoria Taxi Vehicles with 4.6L SOHC engines built at the St. Thomas Assembly Plant from November 22, 1997 through December 15, 2000.
• Certain 1998 through 2001 Lincoln Town Car Limousine Prep Package and Livery Vehicles with 4.6L SOHC engines built at the Wixom Assembly Plant from November 22, 1997 through December 15, 2000.
Sep 23, 2011 | 2001 Ford Crown Victoria
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    I can't touch brakes easy enough when I'm navigating a slow speed in gravel or uneven surface, it's s'posed to have abs but the front wheel wants to plow sideways when I'm going @ walking speed
    This may be a non-factory fix for pushing gravel ( other than staying out of gravel with a 700 pound street bike). With the ignition on and the engine dead, pull on the brake lever with one or two fingers just enough to make the brake light flash at 120 cycles (fast), start the engine while continuing to keep slight pressure on the lever. Keeping the lever slightly pulled will give only 15% brake capacity with no servo assist. Once out of the gravel, release the lever and when the brake light flashes at 60 cycles (slow) pull away safely and never return to the gravel. Ha!
    May 18, 2010 | 2003 BMW R 1200 CL
    Engine light keeps flashing and all tar,snow and gravel lights
    USUALLY A FLASHING ENGINE LIGHT MEANS A MISS FIRE CODE DID YOU HAVE THE VEHICLE HOOKED UP TO A SCANER? IM NOT UNDERSTANDING WHAT YOU MEAN ABOUT THE SNOW GRAVEL AND TAR LIGHTS
    Jun 25, 2009 | 2003 Mitsubishi Lancer
    Computers & Internet Logo
    22 people viewed this question
    David Payne
    David Payne
