Question about KitchenAid KGRS807SSS Gas Kitchen Range
Knob area getting very hot
After baking at 350 degrees and turning off oven, the area around knobs gets very hot. it is cool while cooking, but heats up after around 30 min.after shutting off oven. is this normal? the other areas are not getting hot. we are worried that this will cook the computer.
  • 473 Answers
SOURCE: we just purchased the KGRS807SSS gas kitchen range
This is normal. Typically the vent from the oven will come up between the cooktop and the control panel.
Posted on Oct 05, 2007
0 characters
1 Points
Viking Thermostat bad - Feels like Little House on Prairie
It does not sound like the guy is trying to rip you off. Most mechanical thermostats are adjustable by a center screw in the oven control knob stem behind the knob. The problem is when an oven is off by more than 30 degrees they become almost impossible to calibrate correctly and it is better to replace it. There would not be any danger in just using the thermometers and just living with the problem. It would be a very expensive fix for a Viking and if you can live with it then you are better off. The parts alone will probably be over $300 and then there is the labor charges. The thermostat assembly also includes the tempature probes so it requires major range dis-assembly to replace it. Sometimes the oven control knob will have an adjustment screw on the knob istelf(back of knob) to adjust the position of the dial ring to match the correct oven tempature. This can allow you to change the position of the knob to match the actual tempature of the oven. They usually will only go 30 degrees one way or the other though. So my advice is that if you can live with it and are able to still cook properly then put off fixing it. If you find that over time the cooking tempatures start increasing then you might have no choice but to have the thermostat assembly replaced.
Apr 11, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Oven will not heat up completely
Try the following---
1.) When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
2.) When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jan 31, 2009 | Maytag MER5870 Electric Kitchen Range
I cleaned my oven recently and no matter what temperature I turn the oven too, it cooks way too hot. I performed a test and set the oven temp to 100 degrees celsius. I inserted a thermometer into the...
If your burner always heats to "high" when it's on--regardless of how you set the burner knob--the switch contacts are shorted closed. Check the circuit for any other grounds, then replace the switch.
Apr 15, 2008 | Kitchen Ranges
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Feb 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
We just purchased the KGRS807SSS gas kitchen range
Sep 28, 2007 | KitchenAid KGRS807SSS Gas Kitchen Range
GE modelJBP65G V2AD hitchen range
it sounds like your TO8 CONTROL it is you oven controls and clock. let me know if you want to replace it ..
Aug 24, 2007 | GE JBP65 Electric Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
42 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
