Question about Sony VAIO Computers & Internet
Crash dump - VAIO Sony Computers & Internet
If this is your crash dump then try installing an original windows.
If that doesn't solve then try opening your laptop back lid and remove RAM clean it and insert it again.
Awaiting for your reply
Posted on Aug 01, 2013
Bios not compliant----windows crash dump
check the ram on the pc/laptop. a ram problem can cause this problem.
Nov 07, 2013 | google.com
Crash dump when burning dvd's in premiere elements 7
Checking Event Viewer should give you more details. Right click My Computer > Manage > Event Viewer. Check Application and System by Source. You can filter by warnings and errors in View Or try another burning software. CDBurner XP is free.
Aug 26, 2012 | Adobe Photoshop Elements 7
My emachine keeps dump crashing
it happens when u use ur com continously 10-12 hrss.....
Aug 20, 2012 | eMachines ET1161-07 Desktop PC
When i click on training it causes a crash dump
here are instruction to fix crash dumo to your sega football manager 2011
Step 1shock.gifpen up your steam
Step 2: Go onto your games list
Step 3: Right click on Football Manager and select properties
Step 4: Select the Local files tab on the far right
Step 5: Click the option Verify integrity of game cache
Step 6: Click the option Defragment game cache
It should now be complete
this worked for me
I'm sure there are other people out there who have had there game destroyed by Crash Dumps errors, sometimes screwing your save, sometimes even preventing you from starting new games forcing you to re-install only to come across the same problem later down the line.
So here is my 2 part guide to Crash Dumps, part 1 is how to set your game up to minimize the chances of your game ever getting this error, and part 2 is what to do to recover your save (If possible) and get your game back to a working state if you had this error already. Part 1 pretty much lists all issues that cause Crash Dumps and to set your self up to prevent it from happening.
Crash Dumps Prevention
There are certain things that increase your chances of getting an error, here is a list
1) FMRTE - Just dont go there, it screws your data base up beyond repair, you will not be able to get your corrupt save back if you have used this editor. Sometimes its been to known to cause damage to your windows registry too, unless SI make an official in game editor, using third party programs like this is all to risky stay away.
2) Size of Game - Even though I believe I have found the solutions to 99% of crash dump issues, it does not change the fact the game is not without major issues, the games coding causing endless memory leaks that lead to Crash Dumps errors.
So what I'm saying is try to go easy on your database size, either slow or at most medium size data base when starting a new game.
Also dont go crazy with the amount of leagues you select to be playable, if you have a good system 10 leagues at max.
If you must have lots of leagues and large data base I recommend you have at least 6GB of DDR2 or DDR3 ram, if you have an older system DDR ram will not cut it for crazy data base sizes.
3)Everything Up to Date ? - Make sure the following are up to date
+ Graphics Card Driver (Use manfactures site, sometimes windows will not find the most up to date driver)
+ Java - Make sure you have the latest Version
+Direct X - Latest Version your system is compatible with
4) General Settings in Game These are optional but I recommend you use these settings to prevent errors.
Uncheck the following boxes
+Use Skin Cache
+ Enable Data Collection (This is an important one, it will stop FM constantly building up the RAM useage and prevent Crash Dumps)
+ Play in Windowed Mode, Minimize, and Maximize Every Hour.
+ Disable sounds, and 3D cameras, the 3D sucks anyway text all the way.
+Play with Autosave weekly, 3 file rolling save for back ups, better safe than sorry.
+ Uncheck Threading, if you have a Dual Core processor, you do not need this to be checked, it takes away a complication. However if you have one processor with Threading technology keep it ticked, other wise the game performance will be poor.
5) Your Hardware Before Playing FM 2010 you need to be confident your hardware is all fully working, so you can rule that out if you need to trouble shoot in case you get the Crash Dump.
Consider and do the following before installing the game
+Power Supply - Is it at a high enough Voltage for my Graphics card ?, find out and upgrade power supply if need be, you should not be using a Graphics card if your power supply is under the recommended amount, your system will become very unstable, let alone Football Manager.
+Hard Drive Error Free, run Chkdsk, a windows tool to see if your hard drive has any errors.
To run chekdsk press the windows button and R, then in the run box type in CMD, the in the black command box type in chkdsk and press enter.
You should have a report of no errors, or windows will fix errors
+ Faulty RAM - This was the culprit for me, run a program called MEMTEST86, you need to download and Burn it to CD, restart your PC with the CD in the drive and let it scan.
If you are error free all good, if not note which RAM slot is reporting errors, remove or replace that RAM.http://www.memtest86.com/
+Dust Bunnies - Your system would be unstable in general if you have these, if it is a little unstable check the innards of your PC for obvious dust, blow to free dust from sensitive areas.
If you ever get Blue Screen errors while browsing, gaming, multi tasking, then Football Manager will certainly Crash Dump you ***.
Okay if you follow all these steps prior to installing your game you are very unlikely to get the crash dumps error again.
please rate me if this help you thanks...
Jun 05, 2011 | Sega Football Manager 2011
I am using nComputing L230 Terminal but when I log in from the terminal, the windows and all related applications crash with exception code c0000005.
Uninstall your vSpace software, reboot, download and run their cleanup utility located at www.nc-eng.com/tools/ncuninstall.exe. Apply ALL MS service packs. Verify that no device drivers are missing or conflicting. Logon/logoff to the host and confirm proper functionality. Enable the Windows Startup/Recovery to capture a memory dump. This is done by the following steps: Right click on My Computer ' Properties ' Advanced Tab ' Startup and Recovery, Settings Button, Make sure Kernel Memory dump is selected. From there you can analyze the crash dump. Additionally, to help us, providing the complete hex code when the system crashes would help. Also, you never indicated what OS you're on or what version of vSapce you're using. All this is necessary to help you further.
May 18, 2011 | NComputing L230 Network Terminal
System crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
Mar 26, 2009 | Acer Aspire 4315 Notebook
How to slved the bule screen problem
The best way to solve a blue screen problem is to look at the dump file and get the bucket id from the dump file.
This is the best article i have come accross to analise dump files is this http://www.networkworld.com/news/2005/041105-windows-crash.html?page=1
once the have the bucket id it should tell you what caused the crash
Feb 19, 2009 | Microsoft Windows Vista Ultimate Edition
2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Apr 16, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
