Question about Radio Communications
I have a 1989 cobra 29 Ltd classic cb. It got water spilt on it sitting on my tabble so I took the covers off and took a heat gun to it and dried it. I also disconnected the internal speaker and left it off. N I didn't wanna wire it to my pick up to make sure it worked. But I had a messed up extension cord so i wired it to my cb. When I went to plug it in it sparked at the outlet and blow the fuse on cb power cord so i put a new one in and wired a cigeret lighter plug on it and pluged it in my truck. Wouldn't turn on. It blew both fusses on the plug and wire. I changed the wiring with one that has a different type of fuse n still just blowing fuses. How do I fix it
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
# 1 you should never dry out a radio with a heat gun.#2 the reverse polarity diode is what is blowing out. take that wire you fixed and toss it.go to Rad Shak or a truck stop and buy a power cord with a lighter plug attached. .Then have someone you can trust replace d23. hook up your coax then your cord turn it on and you are good to go.
Posted on Oct 28, 2013
  • 773 Answers
SOURCE: I need Wire diagram for Cobra 29 LTD Classic CB
http://xbones_antennas.tripod.com/id21.html
Posted on May 03, 2009
  • 87 Answers
SOURCE: Blowing fuses with wiring CB to battery
Is the wire going to the battery touching chasis ground at all? Accidentally pinched it, cut wire etc? If not the the power supply may be fried.
Posted on Jun 04, 2009
  • 219 Answers
SOURCE: 29 LTD CB Radio: whats the color to number wiring for cobra mic...
This is for a cobra CA50 mic
1-sheild
2-white
3-red
4-black
Posted on May 09, 2010
SOURCE: What's your problem? my copra 148gtl always
More than likely the RF power transitor/module is short circuit. The usual cause is a faulty aerial.
Posted on Nov 21, 2011
One Wire
  • 126 Answers
SOURCE: Brand new Midland 5001z 40 channel cb blows fuses its turned on
Where did you buy the radio at? Can you return it to the store? If you purchased it at a big box store, like Walmart, they will take it back without a receipt on an exchange.
More than likely the radio was wired backwards by someone, which blew the protection diode, and then was returned to the store and put back on the shelf.
If it is just a blown protection diode, it is only a $10 fix at most any cb radio shop.
If I can help anymore, please let me know.
Dean Pitts
Rollin CBs
dean@rollincb.com
Posted on Mar 06, 2012
When it's dry, I can't transmit, but when my antennas get wet,transmission doubles, WHY????
Hi John:
Try checking where the antenna is connected to the cable.
It may be corroded and you're not getting continuity unless it is wet.
Jan 08, 2016 | Cobra 29-LTD 29 LTD Classic CB Radio
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
How to fix the dimmer light ona cobra 29 nw ltd classic
HI I AM TRYING TO FIX MY 29 COBRA LTD IT WENT OUT ON ME
Feb 04, 2011 | Cobra 29 LTD CB Radio
My 29ltd NW Classic will power up but will not transmit or receive. Occasionally it will, but then suddenly go dead. Sometimes I can tap on the bottom of the cb and it will kick back in momentarily, only...
hi I had the same problem on my cobra uk 29 ltd st night watch it turned out to be dry solder joints if you remove the top cover and look to the right of the board you should see a oblong silver protector cover i found if i taped it lightly it worked then it didnt so i removed it the dry joints were under there hope this helps.
Jan 29, 2011 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
No TX Power
If it is classic it is a 2SC2029 driver transistor.
Nov 18, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
May 05, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
