Question about Onkyo TX-DS989 Receiver
Onkyo 989 Can I replace the condensator for the
Onkyo 989 Can I replace the condensator for the memory backup, and where can i get this?
Why my onkyo ds 989 can't turn it on,tks
Hi VenoBaaurora, if this has not been resolved the unit would have to go to service as it does not power on, you can locate an authorized service center at the following link, http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav, Thanks, JT
Feb 27, 2015 | Onkyo Audio Players & Recorders
I have onkyo ds 989,how i can reset my ampli,tks
Hi Venobaaurora,
To do the reset you need to turn the receiver on then on the front panel of the receiver press and hold the "VIDEO1" button while doing that press the "POWER" button. You will see the word "Clear" in the display screen and the receiver is reset back to factory default settings. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver is reset you will need to go thru the setup menu for all custom settings, Thanks, JT
RE: OnKYO CR-305TX CD RECEIVER Why do the "saved"
There shouldn't be a battery inside but a super capacitor that is supposed to keep the station memory...may be the capacitor is defective...it should be located on the tuner/radio board and may have a high value such as .47Farads at 5 volts...you may need a tech to replace if you have no working knowledge of circuits , but if you do , you should be able to obtain one at radio shack...they sometimes call these capacitors memory backup capacitors
Apr 27, 2011 | Onkyo Audio Players & Recorders
Just purchased a Panasonic DMT-350 with analog 7.1 out and hooked up to my Onkyo 989 but tried everything and i mean everything to get my rear surround to play but no luck....pleeeeeease help me.
Hi.
Connect the Panasonic to one of the AV inputs on the Onkyo. Use red white and yellow AV cables. Connect the output from the Panasonic to one of the five AV video inputs on the Onkyo (or use the DVD dedicated input in the Onkyo backpanel). I indicated this option using red arrows. You can use any of the AV inputs or the DVD input at the bottom. Just ensure you do not connect to an output at the back of the Onkyo.
Alternatively use component cables and optical audio input, as indicated using the blue arrows in picture below. Select source and listen surround from the Onkyo.
There are more options. In some case you may decide to connect the DVD video output to TV and the audio to the Onkyo.
Here a manual for the TX DS989.
Here the backpanel:
Dec 26, 2010 | Onkyo TX-DS989 Receiver
Onkyo receiver memory power backup not working
How change battery and the battery model
Dec 22, 2009 | Onkyo TX-SR700 Receiver
No sound or video form Onkyo 989 after power surge
There are several types of surge protectors used in most all consumer electronics, only the very low end as exceptions.
They generally will protect against the occasional pike coming from the AC line and not show any signs of failure. In the case of a lightning induced spike they will fail completely and either force the blowing of a fuse or interrupt the AC path.
None of these things are absolute in their protection but are not expensive to replace. You have to expect though, that they did not fail quickly enough to protect the circuitry downstream from them and that their replacement may not give you a working unit again.
About any competent tech can give you an assessment of the chances for a successful repair. In other words, an expert should examine it and will probably charge something for the estimate since finding all the problems is about 80% of the work involved; the other 20% in the replacement of failed parts.
Jan 08, 2009 | Onkyo TX-DS989 Receiver
Onkyo TX-28 Reciever memory function not working
Replace super capacitor in the front board (C712) with part # 598-EDLF473A5R5C .47F 5.5V form Mouser Electronics. I did. It worked.
Aug 13, 2008 | Denon DRA-395 Receiver
Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Jan 27, 2008 | Onkyo TX-SR500 Receiver
Low volume while on both DVD and watching Satellite channels.
call onkyo product support 8002251946 option 6...since they did the mod for u...they should b able to take care of this at a minimal charge if any. alan audio video designs 3822 s. staples cc,tx 3618577236
Apr 30, 2007 | Onkyo TX-DS989 Receiver
Onkyo TX-DS989 Receiver Logo
42 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
