Question about Nolan Helmets N-com B4 - For Nolan N104
I have purchased B4 N-com ... after using it for 2 days I can not turn it back on, when the battery is fully charged ... I try to turn on the radio through the computer and connected my iphone 4s blue and red lights flashing ... volume buttons do not respond when pressed ... but when I called, the connection is disconnected b4 to my iphone ... I've tired to turn back but could not live at all, l I've been pressing the ON button for a long time ... I can only turn the radio through the computer .. please help me
I purchased a portable radio on line from Radio shack and it does not work. One of the springs for a battery came off in the package. How do I get a call-back for a return?
At RadioShack.com we want you to be fully satisfied with every item that you purchase. If you are not satisfied with a purchase, you may return most items within 30 days from date of purchase for a full refund of the purchase price, minus shipping, handling or other additional charges.
Return Policy - RadioShack
https://www.radioshack.com/pages/return-policy
Radio Shack Google Search
Mar 10, 2017 | Radio Shack Televison & Video
Transister rsdio won't turn on or off
Very likely bad batteries in the handhelds. Make certain they have been charged fully and try again. If not, get new batteries. Batteries go bad even not used, sitting in a box or on a shelf. 1999 are likely nicad chemistry and without a professional battery conditioner, I doubt they will take a charge. You could try to charge and dis charge them your self 10-12 times. Sometimes this will work. Fully charge the battery, put in the radio and turn it on until the radio beeps. Do not let it go dead overnight or you make the problem worse.
Sep 30, 2014 | Radio Shack 1999 Radioshack 6 Transistor...
I put in a new battery and now the radio beeps when it is keyed up. I put the old battery back in and it works fine. Both batteries fully charged. Any suggestions?
A beep when keyed up can mean a low battery.
1) It is possible your new battery did not take its initial charge, it can take as many as 3 chargings to 'jump start' a new battery. You might try charging the battery an addition 2 full charge cycles.
2) Try the new battery in another SP50 radio to see if it works, or test with a volt meter, if available.
3) Double check the battery is the correct HNN9018 or equivalent NiCd battery. If you are using an after-market battery, check to see if it is a NiCd. If it is a NiMH battery you will need a fast rate charger to charge it up. (On an SP50 the fast rate charger has a blue button on the tray which needs pressed to put it in fast charge mode)
4) This may sound silly, but check to see you installed the battery the correct way. On a Motorola battery the STOP sign would not be visible when installed correctly.
5) If all these items do not solve the 'new battery' problem, you should return the battery to the place of purchase for an exchange.
Best regards.
Sep 17, 2011 | Motorola For SP50 7.5v 1500mAh NiCd...
When i plug up my charger to my electric scooter it says that it is fully charged but when i unplug it it doesnt move at all
I had a similar problem. When scooter purchased, gave it the full 8 hr charge. Was great. Husband did not bring batteries n that winter from unheated building. If left in cold a trickle charger needs to be on it. Easier to take out and bring in.
Same thing happened. Would charge and said fully charged but one battery(has 2) had a dead cell from being out in the cold. Took to batteries plus(very reasonable) had it checked and purchased.new one. Put in and gave it a full charge. Wonderful ever since. Use it at horse shows to run from trailer to stalls to arena and all over. Constantly forget to turn switch off and still comes through for me. It appears to go into a sleep mode when you forget to switch off. When back to trailer to sleep plug it in. The first 2 days of a 7 day circuit didn't plug in but then started to whenever I took it back to trailer as the strip sign says on platform. Duh!! Love it, love it love it!!!
Jun 11, 2009 | Electric Currie EZIP 500 Scooter
How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Apr 12, 2009 | Motorola Talkabout Distance DPS (10...
Can i replace my ipod's battery??
the solution to this problem is you need a new i pod
Mar 24, 2009 | Apple iPod MA446LL/A MP3 Player
1994 Toyota Tercel DX 4D-VIN JT2EL43T8RO434683
Before you change your alternator try to confirm that it is your problem. If I were you I would first get a battery charger and fully charge your battery, once fully charged try to start the car, If it starts let it run while monitoring your battery voltage, if the the voltage stays around 12-14 volts your alternator is good, however if the voltage slowly drops as the car runs then it is definatly your alternator which is not charging your battery. Although you stated you installed a battery with 10.57 volts and the next day it was at 2.34 which is not normal(unless you live in an extremely cold environment), you could also have a short in your system which is draining your battery.
Hope this helps
Jun 25, 2008 | 1994 Toyota Tercel
Battery Problem
Sorry this isn't a solution, but I wish my 8700 would last even as long as yours does. 2 hours, period. on or off, taking pictures or not, two hours & it's a stone dead battery. Just on the off chance it will help I'm about to upgrade the firmware to 1.3 (I don't really think it will help). After that I've decided to take the camera apart & try to find the problem or possibly just a hack that will let me turn it OFF without removing the battery. I'd as soon have a bunch of bits for the project bin as have to put up with this 2 hour battery life problem. Good luck with your problem, and if I find anything worth while I'll post back.
Sep 28, 2007 | Nikon Coolpix 8700 Digital Camera
Battery life
I know exactly what your talking about, I phoned the company and got the run around, somebody, anybody please help if they can!
Feb 20, 2007 | Pioneer XM2go Inno Satellite Radio...
Battery Problem
Unfortunately, I think you have a bigger problem.
Ideas:
1. In the interest of not costing you extra money, wait a few days to see if anyone has any last-ditch ideas.
2. Your battery is probably completely dead. Try purchasing a new one (Amazon.com is good).
DO NOT THROW AWAY THE OLD BATTERY!!! If the new battery still does not work, the old one has probably been shorted by the charger, but it might not have been, and you will now have two working batteries.
3. If that doesn't work, then like I said, you probably have a short in your charger. Refer to
http://www.fixya.com/support/t395532-not_turn
For the solution.
You can try these solutions in either order, but this is the order i suggest.
Happy fixing!
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Nolan Helmets N-com B4 - For Nolan N104 Logo
Top Nolan Helmets GPS Experts
Are you a Nolan Helmets GPS Expert? Answer questions, earn points and help others
