Question about Kitchen Appliances - Others
Scotsman AC206 doesnt make ice just water coming out
4 Suggested Answers
farfield
  • 462 Answers
SOURCE: Scotsman ice machine(sce 275g)
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Posted on Jun 02, 2009
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
  • 129 Answers
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
Posted on Feb 25, 2010
I have a scotsman CM3 with aquaarmor ice machine. There is a constant trickle of water coming from each leg. Why is the happening???
Try taking off a side or back panel and see if there is frost building up. If frost is present, it could be low on refrigerant.
If there is condensation, it could be the insulation is saturated with water allowing thermal transfer to condense water out of the air.
Feb 06, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Not makeing ice
There could be over 50 things that will not let that machine make ice so help me out. when in freeze mode is compressor running, is condenser fan running, is water pump running, check condenser coil to make sure it's not full of dirt if so blow it out, cut machine off if water sump tray is full of water and you can still here water coming in at all check water flote to much water coming in all the time will not let water freeze. Fell evaporator plate while running if warm to touch could be hot gas valve letting hot gas in to plate in freeze cycle. you need to call a service company
Jan 08, 2014 | Scotsman Kitchen Appliances - Others
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Ice machine does not fill reservoir does not fill
Is there a water filter on the system? also the line might be clogged from the inlet to reservior
Jun 13, 2009 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
