Question about Home
Gsi toilet seat where to buy fixing screws in Sydney
dragonsthatk
  • 547 Answers
SOURCE: Jacuzzi Whirlpool toilet EZ33959
any one should fit
Posted on Feb 21, 2009
bearsfan7538
  • 119 Answers
SOURCE: How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Posted on Nov 15, 2009
  • 1206 Answers
SOURCE: Caroma Sydney 305 toilet growls
this is caused by a slight leak in the wax ring causing a gurgle sound, remove it again and reset the wax ring should solve your problem. .
Posted on Jan 26, 2010
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
  • 3074 Answers
SOURCE: My Toto toilet does not
this site may help, Tim:
http://www.guillens.com/Toto/1P_Toilet/Prominence_MS894114.htm
Posted on Jan 10, 2011
Testimonial: "Perfect suggestion!! The picture chart at this website made it easy to find my unidentified part!"
Trying to find a replacement toilet seat for Bellavista Stylo white toilet in Sydney Australia
I had this problem also. Reece Plumbing sell replacement soft close seats, as do Bunnings. Also call Ostar International116 Milperra Road, Revesby NSW 2212 Phone: (02) 9773 3788, to see if they can assist.
Make a cardboard outline of the top of the bowl to match the geometry.
Oct 02, 2015 | Home
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
Where can i buy spare toilet seat screws and fixings for monda rococo toilet suite?
Try to see if you can get them at Lowe's or Home Depot hardware stores. IF you can't geet them there. Try Googling ir or searching for it online. :-)
Jan 18, 2014 | Home
Toilet seat too loose
Is the nut thats on the under side fastened all the way and If you've done that and the screw keeps getting loose then the threads inside the nut or on the screw may be worn away. If thats the case, you may have to by some new screws and I'm not sure if they sell those separately you would usually have to buy a new toilet seat to get new screws, but try home depot or walmart.
May 10, 2013 | Home
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Me top just broke
two screws at back of seat is two square caps lift caps there is either two philips screws or two flat head screws when you grab screw driver get a pair of pliars to hold nuts on bottom of the screws hold the nuts as you are loosening the screws then just go to the home depot or supply store you like get toilet seat that is egg shaped buy and put in old ones place
Mar 11, 2010 | Ergo Toilet Seat - Elongated -Curve -...
Jacuzzi Era elongated seat attachment
first need to buy the longer oval seat so it sits correctly at the front most mounting screws are universal-- go buy thin rubber washers and trim and place between the hinge and bowl than tighten down this will stop slippage but the front if not correctly sitting on the bowl will still cause problems
Jan 22, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Hello - my toto toilet seat broke where the bolt holds the seat to the toilet
well you can go to home depot and get your self new seat with bolt or you can buy the screws for it
Aug 10, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Aug 01, 2009 | Villeroy & Boch Home
Home Logo
42 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
