Ds40 printer error
Incompatible media size 00310
"Incompatible Cartridge" error
Try uninstalling printer, reboot computer then reinstall printer drivers. do not accept HP updates as they block non HP consumables. Update manually if needs must.
May 09, 2013 | HP Officejet 6310 All-In-One InkJet...
HP7130 Incompatible settings
Please , you have to download the driver for win8 ,by samply serching on google.com for example "
HP Officejet 7130 All-In-One driver for win 8
Mar 21, 2013 | HP Officejet 7130 All-In-One InkJet...
My fuser is to hot to print transfer paper
Hi Stacy,
This usually happens if you have incorrect settings in Printing Preferences.
Check your printing preferences like, Media type, Media Size, Print Quality settings.
A fuser issue usually occurs if the imaging drum is heated more due to incompatible/incorrect settings in Printing Preferences of Printer ( under Control panel/Printers Folder )
If this happens, You need to disconnect the power cord of printer from wall outlet and keep the printer shut for atleast half a day
Regards,
Sean
Feb 15, 2013 | HP Color LaserJet 5500 Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
Blue smudge marks are printing on the edge of the paper
These defects normally occur when printing is attempted on unsupported media or when the printer is set up for a different type of media than the media that is actually loaded into the machine.
Check your media and ensure that it is suitable for use in the printer. Refer to the printer's user manual for information on supported media types and weights. Is the media you are printing on supported in the printer?
Ensure that the paper type is set accurately on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type). Is the paper type set correctly on the printer operator panel?
Change the paper weight setting to heavy on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type/Heavy Paper/Check button). Try printing your document again. Did the error return? If the error returns, please contact Lexmark Technical Support for further assistance.
Jul 12, 2011 | Lexmark C532n Color Laser Printer
How to fix error 41.3 on a HP P4515 printer. Have checked all paper settings and tray settings.Changed paper pick up rollers also.
Hi
This error means that the media in tray XX doesn't meet the specified standard of the tray. The specified tray is loaded with media that is longer or shorter in the feed direction than the size configured for the tray. Please check the paper size in current tray or touch OK to change the tray.
To resolve this issue Touch OK to display tray size. Reconfigure the size in the tray so that it uses size of media required for the print job. If the message doesn't clear automatically from the control-panel display, turn the MFP off, and then turn the MFP on.
Restart the printer and repeat the above procedure if issue is not resolved.
Daniel Scott
Jun 14, 2010 | HP Office Equipment & Supplies
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Nov 20, 2009 | HP OfficeJet 9120 All-In-One InkJet...
34 incorrect media
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Dec 18, 2007 | Lexmark C510 Laser Printer
134 people viewed this question
jasbo
jasbo
