Question about Kodak V803 Digital Camera
Setting Details appear on playback screen
When I play back my pictures all the setting details appear on the screen therefore covering the pictures which is very annoying..Is there a setting to turn this off.
  • elainemull Sep 04, 2007
    When I look back at the pictures which I have just taken..the setting details appear on the screen i.e. the image quality, date, type of picture etc. Is there a way of switching these details off as they cover the picture. After a second or two they will dissappear but I want to turn them off altogether.
  • Anonymous Jan 25, 2008
    same problem. Can't get rid of images
    President:
  • 1,114 Answers
We need to know the make & model of your camera to advise as they are all different. Best regards, Informatica.
Posted on Sep 01, 2007
  • Greg Cann
    Greg Cann Sep 02, 2007
    For the Olympus 720SW use the zoom buttons in playback mode to select the different views available, see page 11 in the advanced manual.
    You can download the manual from the link below:
    http://www.olympus.co.jp/en/support/imsg...
    Please update the question & let us know if the information given was useful to you - Good Luck!
  • Greg Cann
    Greg Cann Sep 04, 2007
    If your camera is the Olympus 720SW then the only options I know of are in the original post. I see no way to turn the information off altogether.
    Best regards,
    Informatica.
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
Picture distortion
check the settings on the dvd as if you set the dvd to 4:3 format for instance, the picture will be "squashed" to a letter box format and when you play on wide screen it will become "morphed" and mishaped. also if the tv is set to wide all the time, then this will cause a stretching effect. set the tv to auto picture size or "smart" as it is on sony's, with auto 16:9 on.
Oct 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen broken or cracked
you will need to call rca and order one from them
here is a customer service number you can call for more details on how to get the screen
877-794-7977
Dec 10, 2008 | RCA HD52W59 HDTV Projection Television
Can't remove blue PIP (?) section in lower RH corner
I have the Olevia TV with RC-LTU remote, To get rid of PIP just press the (VIEW) button twice.
Nov 13, 2008 | Olevia LT37HVS 37 in. LCD HDTV
My nokia n95 8gb doesnt display some incoming callers names?
Call ID must be activated in your phone. Your cell phone provider customer service must help you with that.
Artgirl
Jul 20, 2008 | Nokia N95 Cellular Phone
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
SONY DSC-W100
it can be possible to select reset icon by selecting menu option.
it is not possible to take this type of pictures because at auto flash mode the subject can't be covered witin flash range .therefore picture may underexposed however the forground within flash range may correctly exposed.If we do all this at flash off mode the motion of subject will appear  as blurred due to slow shutter speed.
Oct 04, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Kodak V803 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
