Question about Kodak EasyShare DX7630 Digital Camera
Joystick not work
The joystick allows the camera to move to an option like up, down, leff, right; but when you click it to select, it does nothing
3 Suggested Answers
SOURCE: my joystick only work up down and right
I had the same problem. I took my Z760 apart and put in a joystick from a used Z760. But the problem is that the joystick comes unglued from the small computer board. Take it apart and put a tiny drop of superglue on the joystick. Use a magnifier to line up the two little tabs in the proper holes. It should work fine.
Posted on Aug 03, 2008
SOURCE: joystick
While trying to fix this problem today I discovered something that seems to help, at least in my case. If I push down on the small button located below the joystick/onoff button, while also tapping the OK button, the camera responds to the OK. (This is the display/info button.) I'm not sure why this works or whether it would help in every case, but it would be worth a try. I've been able to finally set my date and make other changes necessary after recharging my battery.
Posted on Mar 11, 2008
My Nokia 3230 joystick is not working properly. It selects the first option even if i try to move it up, down, right or left. Please tell me the solution. Thanks in advance.
your problem may cause a damage joystick or the top board of your may be damage or loosing connection try to dismantel it properly then remove and put back again all the connection of the top board.
Jul 30, 2011 | Nokia 3230
How do i turn off "File Protect" and be able to delete again. It won't let me delete pictures and there is a little animated figure on the print that says digital camera out to the side with...
You have accidentally selected lock option.You need to select unlock option for the same. Press the menu button and then press right/left button to select the protect menu. Then you need to select unlock and that would turn off file protect.
Kindly accept the solution so that i could get the credit for my time.
Thanks and Regards
taran_2005
Jul 11, 2011 | Vivitar Cameras
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
    Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
    Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
    Hope my solution helps, have a nice day :)
    Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
    How can I use it as a camera? I have it all plugged in and installed but it won't regester as a webcam :/
    Connect camera to PC with USB cable. On camera switch on and press joystick/OK to get menue on screen. Move joystick to get the set-up icon highlighted and press in OK. Use joystick down arrow to move down menue to "USB mode". Use joystick right or left arrow to change setting to PC CAM. Press OK and you should now have camera acting as a webcam.
    Mar 16, 2011 | Fuji FinePix F601 Zoom Digital Camera
    Z525a screen comes on but stays vacant.
    If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
    Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
    Tiny problem
    1. press menu button on the inside of the fold out display
    2. use the joystick type button on the display to move to the left menu
    3. use the joystick type button and move up 2 times.
    4. use the joystick type button and move right.
    5 use the joystick type button and move down 9 times to "clock adjust" and press it to select.
    6 be sure and press it again to save the changes before you exit the menu
    Sep 27, 2008 | JVC Everio GZ-MG130 Camcorder
    Internal memory photos download to sd card
    1. Ensure memory card is inside camera.
    1. Turn on camera.
    2. Press Review button on back of camera
    3. Then Press Menu Button on back of camera
    4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
    5. Select "Internal Memory" option (by depressing the joystick on RHS).
    6. Select "Continue"
    7. Press Menu button.
    8. Press "Review" button
    9. Press "Review" button again.
    10. Press "Menu" button.
    11. Scroll down to "Copy" and select this option by depressing the joystick.
    12. Scroll down to "All", then select by depressing the joystick.
    13. Contents should now copy over from internal memory to SD card.
    14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
    Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
    New JVC Everio MG 130
    Hi, to set the time or date, first press the MENU button (beside the DIRECT DVD button). Nudge the joystick to the left to select which settings you want to edit. Then go up until you reach the general options. Nudge the joystick right. Move the joystick up until you see "CLOCK ADJUST". Here you can set the correct time. The light is really easy to access. In the shooting mode (where you are seeing live video from the lense), nudge the joystick down. The light should come on. Nudge it down again to put it on Auto. It will turn on/off depending on the lighting. Nudge it down a third time to turn it off. Hope this helps!
    Eric
    Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
    Nikon D40X
    Push the 'Menu' button, with the camera turned on, then use your joystick (the largest button on the back, which has four positions: up, down, left and right) to scroll up or down until you see the wrench icon which denotes the 'Set Up' menu. Move the joystick to the right to enter the menu, then scroll up or down to select the different features.
    Just to let you know, Nikon has tutorial videos available for your camera: http://www.nikondigitutor.com/eng/d40x/index.shtml
    They also have the Owner's Manual available: CLICK HERE If you have your serial number available, you can download the printable version, or, if not, you can always download the non-printable version.
    Dec 27, 2007 | Nikon D40x Digital Camera
    Kodak EasyShare DX7630 Digital Camera Logo
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
