Question about Electronics - Others
Yaskawa servopack sgdm 20ada, drive does not power on
User manual
Moscon E7 from SAMSUNG is same as
Yaskawa E7
You can find it at https://www.yaskawa.com/pycprd/products/hvac-drives/drives/e7-drive
Jun 17, 2014 | Electric Electronics - Others
F7 written in ac and shutdown after 5 minute
What error code is displayed? Status of indicator lights? Solid on or blinking? The owner's manual has a comprehensive list of error codes and solutions. Your problem could possibly be corrected by adjusting the settings.
Here's a link to the manual: Chapter 6 will help you tremendously.
http://www.yaskawa.com/site/dmdrive.nsf/(DocID)/AHUG-5K3LNL/$File/TM.F7.01.pdf
Sep 11, 2011 | Inverter Yaskawa F7 Drive
I NEED YASKAWA MANUAL IN PDF MODEL NO: CIMR F7 U42P2
http://www.yaskawa.com/site/DMDrive.nsf/536df907f9fe9d5586256c4e0056b851/86256ec30069e43286256cd700570246/$FILE/TM.F7.01.pdf
Best regards
Jan 26, 2011 | Inverter Yaskawa F7 Drive
Fault display as OPE06
OPE06
PG Opt Missing Control Method Selection Error
Control method with PG feedback
was selected A1-02 = 1 or 3, but a
PG option board is not installed, or
is installed incorrectly.
Verify the control method in A1-02
and/or the installation of the PG option board
Manual link:
Aug 18, 2010 | Inverter Yaskawa F7 Drive
30 KW F7 MODEL DRIVE GETTING CONTINOUSLY TRIPPING WITH OVER VOLTAGE ALARM ?
sounds like as transistor problem check transistors on heat sink and make sure no wires have come unsoldered and also check with a test meter to see if transistors are allowing current or have closed if closed no current replace.
Mar 18, 2010 | Inverter Yaskawa F7 Drive
My drive problem is 0h1 no so how to splve
oh mean,over heat' check the fan of drive
Feb 13, 2010 | Inverter Yaskawa F7 Drive
I have a fault code on a yaskawa varispeed f7 drive
Go to this link for manual.
http://www.e-mechatronics.com/en/product/inverter/f7/catalog.html
Jun 21, 2009 | Inverter Yaskawa F7 Drive
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
