HTC Touch Diamond Smartphone Logo
A
Anonymous Posted on Aug 01, 2013
Camera not working, device exe error - HTC Touch Diamond Smartphone
Camera launcher.exe does not work anymore
you probably need to uninstall
and re-install the canon program
and ,if you want to fix launcher.exe,There are 3 step to repair launcher.exe stopped working error
If you got launcher.exe stopped working error then there is a 94% chance that your computer has registry problems. To repair launcher.exe stopped working error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair launcher.exe stopped working error.
Hi. I have a Toshiba Satellite L25-S119 laptop. I just bought a Microsoft Lifecam HD-6000. However, when the Microsoft Lifecam application launches I get an error message -> lifecam.exe has...
The first thing to try would be to right-click on lifecam.exe and run it as administrator. If that does not resolve the problem. Then open Device manager. Start->Run-> In the run box type in devmgmt.msc and hit enter. See if the camera has been detected under imaging devices and let me know
4helpful
C:\Program Files (x86)\TOSHIBA\TOSHIBA Web Camera Application\TWebCamera.exe The application has failed to start because its side-by-side configuration is in correct. Please see the event log or use...
Hello, I have Toshiba Satellite L675 Model lap top. My web camera failed to initialize the application. The error message said check your camera device and restart your computer or application again. But it is not still functional. My question is Is the model built web camera? how can I check the device? how Can I solve the problem to be my web camera functional? Thank you for help
I get an error message LifeCam.exe has
Problem with your Cam driver 1st You download Webcam Driver. Free Microsoft Camera Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Why is my computer unable to load various drivers?
The driver is NOT digitally signed so in actual fact they indeed are NOT being installed. You will have to turn of the check digital signature by pressing F8 at Bootup and selecting it. Then you can install it. Install as Administrator, Set the install .exe & run .exe, to Compatability Mode for XP SP 2. You WILL have to press F8 each and every time you boot otherwise Vista will "Block" the driver from loading. There is NO real workaround.
2helpful
2answers
Ceccmdll.dll cec-MAIN.EXE HAS STOPPED WORKING
Have you just installed a new security app such as Kaspersky?
If so you could so allow CEC_main.exe in the firewall which should cure the problem.
12helpful
3answers
Error 8007045a: cannot create video capture filter. I get this error when i have installed the google video and chat. i have an INTEX IT-305WC night vision camera. when i go to devices in the camera exe...
I have windows xp and my web cam is pc camera 120 when I opened webcam nothing is displayed on the cam. It is displaying black screen. When I selected google camera adopter it is displaying 8007045a error. How can I solve my problem.
Sound driver problem at xp
1.instal sp36880.exe (Intel Chipset Installation Utility for ICH8 2K_XP)
2.instal sp33867.exe (Microsoft UAA Bus Driver for HD Audio)
3.try instal sp36090.exe (Conexant High Definition Audio) but 99% with errors !!! (extract to C:\sp36090 )
4.in DEVICE MANAGER / SYSTEM DEVICES
right click on PCI DEVICE (there is yellow trouble icon), manual search "C:\sp36090" and final instal DEVICE )
5. then instal next devices :))
sp36089.exe (HDAUDIO Soft Data Fax Modem with SmartCP)
I hope it would work for as it worked for me as well:)
2helpful
Photo Keychain Won't Work
Found this on Yahoo.
1. Download the drivers from here: www.mscustomercare.com
2. Make sure the device is fully charged and not in charge mode.
3. Unzip and install the drivers with the device connected to your pc.
Try to see if that fixes the issue
Jul 11, 2008 • Cameras
5helpful
2answers
Communications helper.exe
Sounds like Communications helper.exe its some type of driver and/or windows service. This would be the same for all cameras and other computer devices that utilize the Communications helper.exe driver/service. It might be possible to stop Communications helper.exe or its alias from running at start-up but its not recommended as you probably will loose functionality of the camera.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
