Question about Microsoft Surface 64GB Windows RT - with Touch Cover Black
Enter bios mode - Microsoft Surface 64GB Windows RT - with Touch Cover Black
I cannot access the Internet since February 2013. Had 100% internet connection before that.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html i device arrows key scroll to nstalled.
Apr 02, 2013 | Samsung Galaxy Note 10.1"
I forgot my password on my viewsonic viewpad 7e
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps
Sep 26, 2012 | ViewSonic ViewPad 7 Android Tablet
Forgot username and password for IBM thinkpad x41
Back up your most important data to an external storage device in case anything goes wrong while changing the BIOS settings. Remove any disc that is currently inserted in the IBM Thinkpad X41's disc drive.
2-Shut off the Thinkpad X41 laptop. Turn the laptop back on and wait for the "To interrupt normal startup, press the blue Access IBM button" message to appear on the screen.
3-Tap the blue Access IBM button at the top of the keyboard. Click the "Access BIOS" button when the "Rescue and Recovery" menu appears.
4-Click "Yes" and wait for the BIOS to load. Type in the current BIOS password for the IBM X41 and press Enter.5-Navigate over to the IBM's "Security" heading by tapping the right arrow key twice. Scroll down to the "Supervisor Password" listing and press "F5."6-Type the IBM's current BIOS password and hit Enter. Leave the next field blank if you want to completely remove the BIOS password, or instead type in a new password to replace the old one. Press Enter.7-Press "Escape" and then highlight "Restart" and press F5. Navigate to "Save changes and Restart" and press Enter.
  • Nov 05, 2011 | IBM ThinkPad X41 Tablet PC
    Disable BIOS Administrator password
    Enter BIOS SETUP. Enter the current password.
    Change it to a "blank" password.
    Or, if you don't know the password, find the orginal sales-receipt, to prove to HP that you are _NOT_ a thief in possession of the stolen computer, and then HP will assist you.
    Aug 24, 2010 | Compaq 2710p Tablet PC
    How can i enter the bios environment on toshiba portege 3500 tablet pc
    hold the "esc" key presed during boot, and then pres the "f1" key and you enter to the bios
    May 20, 2010 | Toshiba Portege 3500 Tablet PC
    I cant get into the BIOS from Portege 3500
    Keep hitting escape while starting up. Message will say there is an error and hit F1. Hit F1 and you'll enter bios.
    Apr 18, 2010 | Toshiba Portege 3505 Tablet PC
    NEED TO RESET BIOS PASSWORD AND / OR WINDOWS PASSWORD
    To reset the BIOS password, do the following:
    1: Make sure it is unplugged from the adapter.
    2: Remove the battery.
    3: Take out the 13 screws from the bottom cabinet and lift the cabinet about 1in up.
    4: Gently unplug the speaker cable.
    5: Completely remove the bottom cabinet.
    6: Find the little yellow coin sized battery which is located about 2 inches from where you plug in the power adapter.
    7: Unplug the coin sized yellow battery.
    8: Pump the power switch a few times to discharge what little charge may be remaining in the computer.
    9: Plug the coin sized battery back in.
    10: Flip the computer over and plug it in to your power adapter.
    11: Turn it on and start pressing F2 - the CMOS settings (including the password will have been reset.
    12: Press F9 and then enter.
    13: Enter the correct time/date.
    14: Press F10 followed by enter and it will reboot without a "BIOS" password stored.
    For a windows password recovery there are a few programs that can do the job. I personally like "ophcrack". It is freeware that you can easily find using google.
    Hope that helps
    Jan 15, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
    I'm trying to get into the bios of a toshiba protege m200. i don't know the key strokes to enter the bios
    Click HERE for an instructive website on the M200.
    hold the ESC button down during boot to enter bios.
    Jan 19, 2009 | Toshiba Portege M200 Tablet PC
    I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
    That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
    Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
    On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
    On other makes the procedure can be slightly different.
    Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
    Resolving "Setup did not find any hard disk drives" during Windows .
    Jan 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
    Installing windows without DVD
    The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
    Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
    Microsoft Surface 64GB Windows RT - with Touch Cover Black Logo
    Top Microsoft Tablets & eReaders Experts
    thetraveler
    Level 1 Expert
    Les Morrison
    Les Morrison
    Ruben Caraballo
    Ruben Caraballo
    Level 1 Expert
    Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
