I want to know the serial number of HP OfficeJet
I want to know the serial number of HP OfficeJet 9130 All In One,
  • 27 Answers
Usually tells you on box or in the instruction manual.
Posted on Aug 01, 2013
  • 11 Answers
SOURCE: drivers needed for hp officejet 9130 all-in-one
contact HP for free replacement driver. They are more than happy to help.
Posted on Dec 21, 2008
Teis
  • 340 Answers
SOURCE: no driver for the scanner hp officejet 9130 all-in-one priter
You obtain the driver the for HP office 9100 series, here.
- it is on purpose that I want you to download the older PCL5 driver, asthe new PCL6 can course problems.
If any problems, against all ods, should arise, do write back and I will be here to help you. 69d4c1a.png Regards
/Teis
Sundar2579
  • 26 Answers
SOURCE: Where is the serial number on an HP Officejet
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Posted on Sep 09, 2009
MalKontent68
  • 748 Answers
SOURCE: HP officejet 9130 printer: pages keep printing
When a printer outputs the pages face up (most inkjet printers), then the resulting page stack will be reversed (first page face up, then second face up on top of it, and so on). Most printers offer an option to reverse the print order, so the last page is printed first, resulting in a printed stack in correct order.
Look for an appropriate setting in your printer preferences. It is usually called "start printing from last page" or "reverse page order" or something to that effect.
When you find it and want to make it permanent, remember to change this setting in the "Default print setup", which in Windows printer properties is located in the Advanced tab, bottom left. Setting it in printer preferences only will not make the change permanent for every subsequent print job.
Posted on Nov 13, 2009
SOURCE: Hp officejet 9130 keeps giving me a paper stall
I am having the same problem and can tell you that it is NOT related to the paper roller assembly. I purchased a new OEM part and replaced them.
Posted on Jun 12, 2010
Hp officejet 9130 keeps giving me a paper stall message. Paper keeps jamming
Jun 11, 2010 | HP OfficeJet 9130 All-In-One Thermal...
Just got windows 7 and got the new printer diveres for HP Officejet 9130 but can not get it to print in color. it prints only in B%W. uninstll it and reinstll it few times tryed all the drivers with no...
start menu , devices and printers, right click printer select printing preference, then select color tab at top of popup, on that page check and make sure in the color options box that print in greyscale is unchecked
Jan 15, 2010 | HP OfficeJet 9130 All-In-One Thermal...
Yopu can change the rprinting order from the Print Dialogue box or Printer driver.
Look for the following to change page grouping when printed
and the followintg to change printing from first to last and last to first pages
Nov 13, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Need a service manual for hp 9130 need to remove glass to get to scanner lock/unlock device
If you have an HP Officejet 9130...look on page 18 of this User's Guide for the locotion of scanner lock switch. It's labeled #7 in the diagram.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00092872/c00092872.pdf
If this is not your model, please disreguard.
Oct 15, 2009 | HP Office Equipment & Supplies
A line appears down the length of the page on all copies, printing and scanning. How do I get rid of the line?
All you need to do is clean the top feeder which opens into two parts. make sure you clean the black rollers as well as the small strip of glass you will find when you open the second part of the top feeder . don't be afraid to pull open the top feeder it won't break
Jun 01, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Drivers needed for hp officejet 9130 all-in-one
Dec 21, 2008 | HP OfficeJet 9130 All-In-One Thermal...
Problems with printer
Hi
Can you help me with the software ( CD )
Thanks
Apr 14, 2008 | HP OfficeJet 9130 All-In-One Thermal...
OfficeJet 9130 all-in one
I updated the HP 9130 firmware and encountered the same problem. I turned off the printer, removed all the printheads and the cartridges, closed the printer cover and then turned on the printer again. After seeing an error message on the printer screen concerning the missing printheads, I opened the printer cover, replaced all of the missing printheads and the missing cartridges and then closed the cover. The printer then aligned printheads once as is expected after replacing the printhead and cartridges. Thereafter, it worked normally. I do not know why this procedure worked and if it will work in every case, but for now, it seems to have worked for me.
Apr 10, 2008 | HP OfficeJet 9130 All-In-One Thermal...
HP Officejet 9130 All-in-one HELP!!
What works for me is re-flashing the firmware, even if it is the latest version (3010D).
Jan 15, 2008 | HP OfficeJet 9130 All-In-One Thermal...
jasbo
jasbo
