Question about Saws
The glass plate of my microwave BDMOS15-XE is not rotating. IT is sitting correctly and clean. Robyn
  • robyn eley Aug 03, 2013
    I have a microwave model BDMOS15-XE. Lately I've noticed that the glass plate hasn't been revolving while cooking. The plate is clean and fitted correctly. I'll be very disappointed if I have to purchase a new microwave?? It's only 5 years old.
    Top Expert:
  • Saws Master
  • 44,613 Answers
You may have to take it to an appliance repair shop as some turn tables are drive by a rubber belt underneath outside of the oven. It requires the removal of the outer case at the bottom to access this area.
Posted on Aug 04, 2013
Glass plate does not rotate
Here are a couple videos that show you how to replace the turntable motor and diagnose
Feb 10, 2015 | Panasonic Microwave Ovens
Panasonic inverter microwave combi makes a clunking sound after a few seconds and the plate does not revolve properly, the supplier said it was burnt on food on the spindle but how could food get there, I...
Check the glass plate lines up with the 3 notches on the spindle, if it's not sitting correctly it will clunk, it's just a matter of getting the plate to sit right on the spindle, if still no joy check to see if the spindle is damage or the glass underneath.
Nov 23, 2013 | Microwave Ovens
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
on the bottom of the micro underneath the shield there is a small moter for turning the plate.. also if the plate and roller are not centerd correctly it will not turn ,.. remove the plate and balence a glass on the triangle in the center of the micro shut door and start micro observe if turning ..also some micros have a button selection on the control to reverse the micro plate rotation and stop it --check these things and get back to me..
Aug 10, 2009 | Microwave Ovens
Microwave lights up and glass plate rotates but no heat. Also, unsure how to remove microwave from its surround within kitchen unit.
to almost all of the no heat microwave issues suggest calling company about warranty because the warranty may cover problems like these up to five years and taking them apart will almost certainly void it. Magnatron is likely cause for problem.
Apr 21, 2009 | Microwave Ovens
Kenmore Elite 66469 Turntable "Clunking" Sound
Either the coupler or the turntable support is bad.
You can find an exploded view by entering your FULL model number (3 digits, a dot, then 8 digits) here: http://www3.sears.com (the 3 is correct)
Dec 08, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Saws Logo
49 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
