Paper jam on frontier 340 - Office Equipment & Supplies
2 Suggested Answers
tech-agent
  • 83 Answers
SOURCE: Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Posted on Feb 13, 2010
Frontier 340, cannot get the back printing to print on the photos, the back printing test prints, but not the photos
Is it a photo-printer? Are you trying to print photos on both sides? Most photo paper is not set up to be printed on both sides. It might be the type of paper that would be causing the dual-side trouble.
Elisa Jed ' http://calwestprinting.com/services/reproduction_services/
Jun 26, 2014 | Office Equipment & Supplies
My printer Lexmark X 340 have a error code 200.20. Please help me
Its an Error Related to a Paper Jam on the Paper Roll Tray!!!!!
Please Check the Inside of the Printer if there are any Bits of Paper which are stuck on it!!! That would cause this Error Message to Appear!!!!
Good Luck!!!!
Aug 16, 2011 | Lexmark X342n All-In-One Laser Printer
We have a paper jam according to the display but have found small pieces of paper tucked away but cant find any more is there a reset or is there somewhere more may be that we cant see/get to?
If your machine is detecting a jam with no obvious signs of paper, you most likely have small amounts of debris or dirt blocking the jam sensor. I suggest manually feeding a piece of thick card stock through the paper path, then spray the path with some canned air, as this will act to clear any dirt blocking the jam sensor.
-David.
Nov 03, 2010 | Samsung SF-340 Plain Paper Inkjet Fax
Feb 09, 2010 | Epson Office Equipment & Supplies
SF-341P
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Oct 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Samsung sf 340 printer
i need to download the Samsumng sf340 printer/fax driver
Jun 23, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Xerox 5837 with 08-310 Error
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Jun 03, 2008 | Xerox 5830 Copier
Paper jumped problem
Do you mean jammed?
Usually they don't lie. A piece of paper is somewhere.
Apr 09, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
44 people viewed this question
jasbo
jasbo
