Question about Canon LBP 1000 Laser Printer
Pc load 80r
Load paper 80r plain
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Printer saya bila dihidupkan selalu muncul tulisan load plain white paper and press ok
Check your paper tray and make sure you have the paper loaded correctly and that the paper guides are snug against the paper. There are settings on the menu that you can make sure they are set to plain paper
Mar 19, 2011 | HP PhotoSmart C4280 Laser Printer
HOW DO YOU LOAD sef PLAIN PAPER - WHAT IS THAT?
that is the normal copy paper that the load in the paper draw
Apr 09, 2010 | Ricoh Aficio 1515F Plain Paper Laser Fax
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Which way to laod paper to fax on Brother 560 plain paper fax
Does not matter.
If you mean when sending, make a copy, then you'll be sure.
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
'Load plain paper' message
Make sure that you have set the same paper type on both the printer driver and on the printer itself, using the on-printer menu. When I get this message, I usually had forgotten to change the paper type on the printer.
Jul 30, 2008 | Dell 3000cn Laser Printer
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
Copystar 1635 copier/printer set up problem
What the problem sounds like is that the machine and print driver are set to diifferent paper types.
One says plain paper and the other bond paper.
Or something like that, the machine says bond and the printer plain paper.
Chech the size setting and paper orinentation.
Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached.
Feb 12, 2008 | Office Equipment & Supplies
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
74 people viewed this question
old marine
old marine
