Question about Innovage 69420210126 Phone
Speaker phone 12/24 hour MODE doesn't work
IT TELLS ME TO SWITCH BETWEEN 12/24 HOUR MODE TO PRESS AND HOLD DOWN TOGETHER THE "UP AND DOWN" BOTTONS FOR 3 SECONDS TO SWITCH TO THE 12 OR 24 HOUR MODE. BUT NOTHING AT ALL HAPPENS. HOW DO YOU SWITCH BETWEEN THE TWO ????
The question was how to change it, not how tell which mode it is in.
Posted on Feb 03, 2008
If its on 12 hour it will have am or pm next to the time.when you set it its on 24 hour so if its 8:00 you would set it at 20:00 hours when your done your main menu should read 8:00.
Posted on Dec 27, 2007
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
How do I sync the device to my cellphone?
Hi Elena,
Hold down your power switch for a moment, it prompt to pairing mode and seeks for your cellphone. Make sure your phone bluetooth activated before do this process. Then if nothing goes wrong they will paired. This speaker will work for any brand phones that has compatible bluetooth.
regards
Sep 27, 2011 | Motorola Mobility T325 Bluetooth Speaker...
I lost directions for my farberware kitchen timer. it is battery operated,has a digital display and 4 buttons.(one green ,one red and two black buttons..) i cannot reset the time. if you can tell me the...
I recently bought one. The instructions are on the packaging.
To switch from timer mode to clock mode, press STOP and START together.
To set the clock, press START and hold for 5 seconds until the whole display flashes. Press HOUR to set the hour. Press MINUTE to set the minutes. Press START to start the clock.
Mar 13, 2011 | Sport & Outdoor - Others
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
Memorex travel speaker with ipod dock speaker system black I cannot set the clock on this item
Hold the "Time Set" button until the time starts flashing, then press the "play/pause" button so that only the hour is flashing. Use the ">>" and "<<" buttons to set the desired hour. Once the hour is set, press the "play/pause" button again so that the minute is flashing. Again, use the ">>" and "<<" buttons to set the desired time.
To change to military time from am/pm, hold the "Time Set" button until the time starts flashing, then press the ">>" button. In order to revert back to am/pm, hold the "Time Set" button until the time starts flashing (if it is not already flashing) and then press the "<<" button.
Sep 16, 2010 | Memorex Travel Speaker with iPod Dock...
How do i set time for an Accurian 40-141 iPod Alarm Clock with Radio?
SETTING THE CLOCK TIME: 1. In standby mode, press and hold MODE to enter the clock time setting mode. 2. Press |<< TUNE/SKIP >>| to switch between 12-hour and 24-hour display. Press MODE to confirm the selection. The digits flash. 3. Press or hold |<< TUNE/SKIP >>| to set the hour and minute. Press MODE to confirm.
Dec 21, 2009 | Audio Players & Recorders
How do I change my Casio twin sensor alti thermo watch from 24 hour to 12 hour format?
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Oct 09, 2009 | Casio Watches
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
How do I set watch as a 24 hour mode clock ?
With TIME displayed, press and hold ADJUST, then press MODE to switch between 12- and
24-hour format.
Nov 02, 2008 | Timex 1440 Nylon watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Innovage 69420210126 Phone Logo
132 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
k24674
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
